Salta al contenuto principale
Replacing Astec Apple IIGS Power Supply Capacitors
Cosa ti serve
  1. Replacing Astec Apple IIGS Power Supply Capacitors, Remove Top Screws: passo 1, immagine 1 di 2 Replacing Astec Apple IIGS Power Supply Capacitors, Remove Top Screws: passo 1, immagine 2 di 2
    • Remove the 2 screws located on the top cover with a Phillips screwdriver.
  2. Replacing Astec Apple IIGS Power Supply Capacitors, Free the Side of Top Cover: passo 2, immagine 1 di 3 Replacing Astec Apple IIGS Power Supply Capacitors, Free the Side of Top Cover: passo 2, immagine 2 di 3 Replacing Astec Apple IIGS Power Supply Capacitors, Free the Side of Top Cover: passo 2, immagine 3 di 3
    • Carefully pry the top cover until the 2 clips near the cable grommet come free from the sides of the case. Repeat for the other side.
  3. Replacing Astec Apple IIGS Power Supply Capacitors: passo 3, immagine 1 di 2 Replacing Astec Apple IIGS Power Supply Capacitors: passo 3, immagine 2 di 2
    • Rotate the power supply and push the 3 clips upwards, one at a time while pulling away from the bottom of the power supply case to free the clips.
  4. Replacing Astec Apple IIGS Power Supply Capacitors, Remove Top Cover: passo 4, immagine 1 di 1
    • Remove the top cover.
    • WARNING! High Voltages are present inside of the power supply, and may be present even after the power supply has been switched off and unplugged. Apple in no way designed this to be serviced by the average consumer, operate at your own risk.
  5. Replacing Astec Apple IIGS Power Supply Capacitors, Unscrew PCB: passo 5, immagine 1 di 2 Replacing Astec Apple IIGS Power Supply Capacitors, Unscrew PCB: passo 5, immagine 2 di 2
    • Remove the 2 screws securing the board to the case and the 2 screws securing the heatsink to the case.
  6. Replacing Astec Apple IIGS Power Supply Capacitors, Remove Cable Grommet: passo 6, immagine 1 di 3 Replacing Astec Apple IIGS Power Supply Capacitors, Remove Cable Grommet: passo 6, immagine 2 di 3 Replacing Astec Apple IIGS Power Supply Capacitors, Remove Cable Grommet: passo 6, immagine 3 di 3
    • Grab the cable grommet and rotate it 90° away from the power inlet and pull it straight out of the case through the cable cutout.
  7. Replacing Astec Apple IIGS Power Supply Capacitors, Remove PCB: passo 7, immagine 1 di 2 Replacing Astec Apple IIGS Power Supply Capacitors, Remove PCB: passo 7, immagine 2 di 2
    • Grab the large heatsink and gently lift the board out of the shell, hinging it along the mains power cables.
    • The large heatsink is electrically isolated so there is no risk of electric shock.
    • You are now ready to replace the capacitors! Be careful while working on the board as any sudden pull on the board may pull out the 2 mains input wires from the board.
  8. Replacing Astec Apple IIGS Power Supply Capacitors, Replace Capacitors: passo 8, immagine 1 di 2 Replacing Astec Apple IIGS Power Supply Capacitors, Replace Capacitors: passo 8, immagine 2 di 2
    • It’s always a good idea to replace capacitors on your power supplies, especially since these are approaching 40 years old, the capacitors have likely failed and/or leaked.
    • Some capacitors may be hot glued to a wire or other components, a precision blade must be used to cut them free from the hot glue without damaging components. In addition, most of the capacitors have their leads bent parallel to the board, requiring you to unbend them before removing the capacitor.
    • There are 11 capacitors total, there are 4 variants of the Astec power supply, all with different capacitor values, check this list to see what variant you have and order the correct capacitors. Along with capacitors, there is thermal compound on the large heatsink that contacts the metal case that also will need replacing.
Conclusione
Cooper Schwartz
Membro da: 11/24/19
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 52
