Salta al contenuto principale
Repairing nose pads on eyeglasses
Cosa ti serve
  1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: passo 1, immagine 1 di 2 Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: passo 1, immagine 2 di 2
    • Remove the screw from the pad arm.
    • If the screw is missing, get a backup screw, and proceed to step 2.
  2. Repairing nose pads on eyeglasses: passo 2, immagine 1 di 2 Repairing nose pads on eyeglasses: passo 2, immagine 2 di 2
    • Insert the nose pad into the mount on the frame.
    • Make sure the nose pad lines up with the screw hole.
    • While holding the nose pad in place, use the magnet to attract the screw head.
    • Make sure the screw is vertical to the magnet and the screw head is above.
  3. Repairing nose pads on eyeglasses: passo 3, immagine 1 di 1
    • Place the screw into the screw hole.
  4. Repairing nose pads on eyeglasses: passo 4, immagine 1 di 2 Repairing nose pads on eyeglasses: passo 4, immagine 2 di 2
    • Using a horizontal motion, remove the magnet.
    • Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
  5. Repairing nose pads on eyeglasses: passo 5, immagine 1 di 2 Repairing nose pads on eyeglasses: passo 5, immagine 2 di 2
    • Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
    • Make sure the screw is tightened enough.
Conclusione
Altre 3 persone hanno completato questa guida.
Vivi Chou
Membro da: 04/28/17
151 Reputazione
1 Guida realizzata
UC Davis, Team S3-G4, Coad Spring 2017 Membro di UC Davis, Team S3-G4, Coad Spring 2017
UCD-COAD-S17S3G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 77
Ultimi 30 Giorni: 356
Tutti i Tempi: 46,880
