Salta al contenuto principale
Repairing a Wobbly Piano Bench
Cosa ti serve
  1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: passo 1, immagine 1 di 1
    • Place the bench on an even surface.
  2. Repairing a Wobbly Piano Bench: passo 2, immagine 1 di 1
    • Open and lock its lid. Make sure it stays open during the whole procedure.
  3. Repairing a Wobbly Piano Bench: passo 3, immagine 1 di 3 Repairing a Wobbly Piano Bench: passo 3, immagine 2 di 3 Repairing a Wobbly Piano Bench: passo 3, immagine 3 di 3
    • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
  4. Repairing a Wobbly Piano Bench: passo 4, immagine 1 di 3 Repairing a Wobbly Piano Bench: passo 4, immagine 2 di 3 Repairing a Wobbly Piano Bench: passo 4, immagine 3 di 3
    • Take the leg out and unscrew the inner hex nut.
    • Replace the washers with the new ones and re-screw the hex nut tightly.
  5. Repairing a Wobbly Piano Bench: passo 5, immagine 1 di 1
    • Connect the leg to the bench again using the new lock washer.
    • Screw the hex nut a few rounds, but do not tighten it yet.
    • Repeat Steps 3 through 5 for all four legs.
  6. Repairing a Wobbly Piano Bench: passo 6, immagine 1 di 2 Repairing a Wobbly Piano Bench: passo 6, immagine 2 di 2
    • Add a little weight to the chair or push it down with two hands.
    • Turn all four outer hex nuts one round.
    • Make sure the bench is balanced and repeat until all hex nuts are tight.
  7. Repairing a Wobbly Piano Bench: passo 7, immagine 1 di 2 Repairing a Wobbly Piano Bench: passo 7, immagine 2 di 2
    • Close the lid seat on the chair.
    • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
Conclusione
You can redo this process every 6 months to make sure your bench is always stable.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,132
