Salta al contenuto principale
Repairing Zipper Slider
Cosa ti serve
  1. Repairing Zipper Slider, Identifying a Bad Zipper Slider: passo 1, immagine 1 di 2 Repairing Zipper Slider, Identifying a Bad Zipper Slider: passo 1, immagine 2 di 2
    • A zipper that separates behind the zipper slider like the one shown on this tent is a very common zipper failure mode on backpacks and luggage too. It's an easy fix with a locking pliers: the goal is to carefully squeeze the top and bottom plates of the zipper slider just ever so slightly closer.
  2. Repairing Zipper Slider, Positioning Locking Pliers to Repair a Zipper: passo 2, immagine 1 di 2 Repairing Zipper Slider, Positioning Locking Pliers to Repair a Zipper: passo 2, immagine 2 di 2
    • With the locking pliers in the locked position: use the screw adjustment at the back to close on the zipper slider. (Make sure you're clamping just the zipper slider and NOT the zipper pulls or fabric.)
    • Remove the locking pliers and tighten the screw adjustment ever so slightly: a 1/16th or 1/8th of a turn should be enough: you're trying to apply the slightest pressure to both sides of the zipper slider when you re-apply it.
    • Return the locking pliers to the proper position on the zipper slider and clamp the locking mechanism down: this time, the locking pliers should lock just a little as you clamp down. Clamp the zipper slider on BOTH sides with the same setting before changing anything.
    • It might take a few tries with successively tighter settings on the locking pliers but eventually the zipper will start zipping properly again.
  3. Repairing Zipper Slider, Miscellaneous Zipper Slider Tips: passo 3, immagine 1 di 1
    • This technique even works with pitched tents, which is typically when you figure out that the zipper needs fixing. It works on luggage, backpacks, any zipper that has a metal slider.
    • If you overdo it with the locking pliers the zipper might get hard to zip. You can open the gaps on both sides in the zipper slider a little with a thin flat blade screwdriver, but it's best to work slowly and avoid that scenario.
    • Don't have locking pliers or vise grip? You can use a regular pliers in a pinch, as this person did with their backpack.
    • Someone took a video of me using this technique to repair a backpack: https://youtu.be/BhehrLek2XM
Conclusione
Congratulate yourself on having saved yourself from replacing an expensive fabric item (or at least a zipper.)
Altre 13 persone hanno completato questa guida.
Fixit Clinic
Membro da: 01/13/15
670 Reputazione
2 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
581 Guide realizzate
2 Commenti
Sometimes the metal in the zip will have become weakened and this method will not work. If this happens try using Zlideon zips. https://zlideon.com/ They are quite expensive but worth the money if the item is expensive or much loved. (Note I am not in any way connected to Zlideon but I have used their zipper replacements several times).
SussexDab - Replica
Literally took two seconds to fix a zipper. THANK YOU
Emma Hochstetler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 57
Ultimi 30 Giorni: 168
Tutti i Tempi: 23,303
