Salta al contenuto principale
Repair Loose Floorboard Carpet in Vehicle
Cosa ti serve
  1. Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: passo 1, immagine 1 di 2 Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: passo 1, immagine 2 di 2
    • Pull back detached carpet from the floorboard to determine how much carpet is detached.
  2. Repair Loose Floorboard Carpet in Vehicle: passo 2, immagine 1 di 2 Repair Loose Floorboard Carpet in Vehicle: passo 2, immagine 2 di 2
    • Apply a generous layer of spray adhesive to floorboard.
    • Wear a mask to prevent inhalation of fumes.
    • Wear gloves to prevent the adhesive from sticking to your hands.
    • Perform repair in a well ventilated area.
  3. Repair Loose Floorboard Carpet in Vehicle: passo 3, immagine 1 di 1
    • Allow 15-30 seconds for adhesive to dry before attaching carpet to floorboard.
  4. Repair Loose Floorboard Carpet in Vehicle: passo 4, immagine 1 di 2 Repair Loose Floorboard Carpet in Vehicle: passo 4, immagine 2 di 2
    • Apply carpet to floorboard firmly using hands.
    • This step needs to be repeated until carpet is in place with no wrinkles or bulges.
  5. Repair Loose Floorboard Carpet in Vehicle: passo 5, immagine 1 di 2 Repair Loose Floorboard Carpet in Vehicle: passo 5, immagine 2 di 2
    • Use a plastic squeegee to tuck the corner of the carpet into the paneling of the floorboard.
  6. Repair Loose Floorboard Carpet in Vehicle: passo 6, immagine 1 di 1
    • Vacuum floorboard to remove any debris or dirt.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 142
Tutti i Tempi: 6,340
