Salta al contenuto principale
Removing the Apple Cinema Display M8149 Display Hinge
Cosa ti serve
  1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: passo 1, immagine 1 di 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: passo 1, immagine 2 di 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: passo 1, immagine 3 di 3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Removing the Apple Cinema Display M8149 Display Hinge: passo 2, immagine 1 di 3 Removing the Apple Cinema Display M8149 Display Hinge: passo 2, immagine 2 di 3 Removing the Apple Cinema Display M8149 Display Hinge: passo 2, immagine 3 di 3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Removing the Apple Cinema Display M8149 Display Hinge: passo 3, immagine 1 di 2 Removing the Apple Cinema Display M8149 Display Hinge: passo 3, immagine 2 di 2
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
  4. Removing the Apple Cinema Display M8149 Display Hinge: passo 4, immagine 1 di 3 Removing the Apple Cinema Display M8149 Display Hinge: passo 4, immagine 2 di 3 Removing the Apple Cinema Display M8149 Display Hinge: passo 4, immagine 3 di 3
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 10-41, Forte Spring 2011 Membro di Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Membri
12 Guide realizzate
Un commento
in 2023 where can I get a replacement stand?
Mitch Leung - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 7,815
