Salta al contenuto principale
Remove PowerMac G4 M5183 Main Fan
Cosa ti serve
  1. Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: passo 1, immagine 1 di 2 Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: passo 1, immagine 2 di 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Remove PowerMac G4 M5183 Main Fan, Main Fan: passo 2, immagine 1 di 2 Remove PowerMac G4 M5183 Main Fan, Main Fan: passo 2, immagine 2 di 2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Remove PowerMac G4 M5183 Main Fan: passo 3, immagine 1 di 1
    • Remove the power cable from the fan and detach bracing.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Justin Petrilli
Membro da: 01/21/10
3.114 Reputazione
11 Guide realizzate
Cal Poly, Team 13-24, Maness Winter 2010 Membro di Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membri
25 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,467
