Salta al contenuto principale
Razer Huntsman TE Keycaps Replacement
Cosa ti serve
  1. Razer Huntsman TE Keycaps Replacement, Keycaps: passo 1, immagine 1 di 2 Razer Huntsman TE Keycaps Replacement, Keycaps: passo 1, immagine 2 di 2
    • Identify the correct type of key to replace.
    • Keys such as "Shift" and "Enter" have multiple slots, and each slot has a different shape, so be sure to pick the correct one.
  2. Razer Huntsman TE Keycaps Replacement: passo 2, immagine 1 di 2 Razer Huntsman TE Keycaps Replacement: passo 2, immagine 2 di 2
    • Insert the keycap puller so that the teeth at the end of the puller sit beneath the keycap.
    • Apply enough upwards force for the keycap to pop out.
  3. Razer Huntsman TE Keycaps Replacement: passo 3, immagine 1 di 2 Razer Huntsman TE Keycaps Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    Compra
    • Apply 91% isopropyl alcohol to microfiber cloth.
    • Wipe around the key.
    • Make sure that there is no residual stickiness on the key.
  4. Razer Huntsman TE Keycaps Replacement: passo 4, immagine 1 di 2 Razer Huntsman TE Keycaps Replacement: passo 4, immagine 2 di 2
    • Position the replacement keycap above the keyslot.
    • Using your finger, apply downwards force to the keycap until you hear it snap into place.
Conclusione
Use a diagnostic tool such as an online keyboard tester to test the key.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 38
Tutti i Tempi: 2,000
