Salta al contenuto principale
Radiator/thermostat valve repair
Cosa ti serve
  1. Radiator/thermostat valve repair, Radiator-/thermostat-valve: passo 1, immagine 1 di 1
    • Fully open the thermostat/valve
  2. Radiator/thermostat valve repair: passo 2, immagine 1 di 1
    • Undo the screw on the fastening clamp. In this case an older thermostat is shown. Newer models probably have a twist and screw cap and you may not need tools at all.
    • Remove the thermostat head.
  3. Radiator/thermostat valve repair: passo 3, immagine 1 di 1
    • Put some multipurpose oil onto the little transmission pin.
  4. Radiator/thermostat valve repair: passo 4, immagine 1 di 1
    • By tapping the pin CAREFULLY with a hammer, you can make it move again.
  5. Radiator/thermostat valve repair: passo 5, immagine 1 di 2 Radiator/thermostat valve repair: passo 5, immagine 2 di 2
    • Add some additional lubrication to the pin before screwing the thermostat back on.
    • By pushing the pin in and let it come back out several times using the hammer again, the oil should evenly distribute on the pin, so that in future it is very unlikely, that it is seizing up soon again.
    • That's it! Put the valve/thermostat back on and fix it in place.
Conclusione
To reassemble your device, follow the steps in reverse order.
Altre 4 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
iFixit EU Team Membro di iFixit EU Team
Staff
45 Membri
1.096 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 192
Tutti i Tempi: 2,685
