Salta al contenuto principale
PowerMac G4 M5183 Graphics Card Removal
Cosa ti serve
  1. PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: passo 1, immagine 1 di 2 PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: passo 1, immagine 2 di 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. PowerMac G4 M5183 Graphics Card Removal, Graphics Card: passo 2, immagine 1 di 2 PowerMac G4 M5183 Graphics Card Removal, Graphics Card: passo 2, immagine 2 di 2
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
Linea Traguardo
Altre 13 persone hanno completato questa guida.
Justin Petrilli
Membro da: 01/21/10
3.114 Reputazione
11 Guide realizzate
Cal Poly, Team 13-24, Maness Winter 2010 Membro di Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membri
25 Guide realizzate
2 Commenti
Do I need to avoid static to protect the board?
Jim Robson - Replica
Es ist eine deutsche Anleitung, aber auf der iFixit Übersicht als Englisch gekennzeichnet.
Toni Makkaroni - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 9,747
