Salta al contenuto principale
PowerBook G4 Titanium DVI RAM Replacement
Cosa ti serve
  1. PowerBook G4 Titanium DVI RAM Replacement, Battery: passo 1, immagine 1 di 2 PowerBook G4 Titanium DVI RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI RAM Replacement, Keyboard: passo 2, immagine 1 di 1
    • Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  3. PowerBook G4 Titanium DVI RAM Replacement: passo 3, immagine 1 di 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
  4. PowerBook G4 Titanium DVI RAM Replacement: passo 4, immagine 1 di 1
    • Your laptop should look approximately like this.
  5. PowerBook G4 Titanium DVI RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
Conclusione
Altre 24 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 14,694
