Salta al contenuto principale
PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement
Cosa ti serve
  1. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement, EMI Finger: passo 2, immagine 1 di 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 3, immagine 1 di 1
    • Remove the long black Phillips screw next to the memory card.
    • Remove the small EMI finger beneath the black screw.
  4. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement, Keyboard: passo 4, immagine 1 di 1
    • On the keyboard, remove the F1, F2, F11, and F12 keys.
    • This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
    • You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
    • When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
  5. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 5, immagine 1 di 1
    • Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
  6. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 6, immagine 1 di 1
    • Remove the two short Phillips screws.
  7. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 7, immagine 1 di 1
    • Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
  8. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 8, immagine 1 di 1
    • Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
  9. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement, Upper Case: passo 9, immagine 1 di 1
    • Remove the three small Phillips screws from within the battery compartment.
  10. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 10, immagine 1 di 1
    • Turn the computer 90 degrees clockwise and remove the two medium-length Phillips screws from the casing.
  11. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 11, immagine 1 di 1
    • Turn the computer 90 degrees clockwise again, and remove only the bottom screw on either side of the hinge.
  12. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 12, immagine 1 di 1
    • Turn the computer 90 degrees clockwise just one more time, and remove the two Phillips screws on the exterior wall of the battery compartment.
    • Remember these two screws are longer and have shoulders.
  13. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 13, immagine 1 di 1
    • Turn the computer over and open it up.
    • Remove the following 14 screws:
    • Six 2.5 mm Phillips on either side of the keyboard area.
    • Five 4.5 mm Phillips on the left half of the keyboard area.
    • One 7 mm hex in the upper left corner of the upper case (a T6 Torx driver will do the job nicely).
    • One 15 mm Phillips in the upper middle of the keyboard area.
    • One 16.5 mm hex in the upper right of the upper case (again, a T6 Torx driver will work well).
  14. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 14, immagine 1 di 1
    • Peel up the two pieces of foil tape on the left side of the keyboard area.
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Carefully disconnect the microphone and power cables from the logic board. Using your fingernails or a dental pick, carefully pry the connectors from their sockets. Make sure you're pulling only on the connector and not on the socket.
  15. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 15, immagine 1 di 1
    • Use the orange plastic loop to disconnect the trackpad cable.
  16. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 16, immagine 1 di 1
    • Starting at one of the upper corners near the screen, work around the frame, separating the upper case from the lower case.
  17. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 17, immagine 1 di 1
    • Lift the upper case off the computer.
  18. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement, RJ-11 Board: passo 18, immagine 1 di 1
    • Disconnect the modem cable from the screen side of the modem and deroute it from the metal framework.
  19. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 19, immagine 1 di 1
    • Remove the Phillips screw securing the display data cable to the metal framework.
  20. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 20, immagine 1 di 1
    • Use the black plastic pull tab to disconnect the display data cable from the logic board.
  21. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 21, immagine 1 di 1
    • Remove the Phillips screw securing the RJ-11 Board.
  22. PowerBook G4 Aluminum 12" 867 MHz RJ-11 Board Replacement: passo 22, immagine 1 di 1
    • Lift up on the left side of the RJ-11 Board and remove it from the computer.
Conclusione
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,535
