Salta al contenuto principale
PowerBook G3 Pismo Optical Drive Replacement
Cosa ti serve
  1. PowerBook G3 Pismo Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Use the lever at the front of your laptop to remove the optical drive bay from the computer.
    • Remove the 2 Phillips #00 screws from the left side of the optical drive housing.
    • These screws are longer than those on the other side.
  2. PowerBook G3 Pismo Optical Drive Replacement: passo 2, immagine 1 di 1
    • Remove the 2 Phillips #00 screws from the other side.
  3. PowerBook G3 Pismo Optical Drive Replacement: passo 3, immagine 1 di 1
    • Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Conclusione
Altre 6 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 8,683
