Salta al contenuto principale
PowerBook 3400 M3553 Display Replacement
Cosa ti serve
  1. PowerBook 3400 M3553 Display Replacement, Battery: passo 1, immagine 1 di 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Display Replacement: passo 2, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement: passo 2, immagine 2 di 2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Display Replacement, Keyboard: passo 3, immagine 1 di 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Display Replacement: passo 4, immagine 1 di 3 PowerBook 3400 M3553 Display Replacement: passo 4, immagine 2 di 3 PowerBook 3400 M3553 Display Replacement: passo 4, immagine 3 di 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Display Replacement: passo 5, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement: passo 5, immagine 2 di 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
  6. PowerBook 3400 M3553 Display Replacement, RAM: passo 6, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement, RAM: passo 6, immagine 2 di 2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
  7. PowerBook 3400 M3553 Display Replacement, Speaker Panel: passo 7, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement, Speaker Panel: passo 7, immagine 2 di 2
    • Disconnect the wires from the port.
  8. PowerBook 3400 M3553 Display Replacement: passo 8, immagine 1 di 1
    • Remove the 7mm screw connecting the speaker panel to the computer.
  9. PowerBook 3400 M3553 Display Replacement: passo 9, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement: passo 9, immagine 2 di 2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
  10. PowerBook 3400 M3553 Display Replacement: passo 10, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement: passo 10, immagine 2 di 2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
  11. PowerBook 3400 M3553 Display Replacement, Display: passo 11, immagine 1 di 1
    • Remove the panels on either side by gently but firmly pulling up on them with both hands.
  12. PowerBook 3400 M3553 Display Replacement: passo 12, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement: passo 12, immagine 2 di 2
    • Gently pull up on the ribbon cable connection that connects the screen to the logic board.
  13. PowerBook 3400 M3553 Display Replacement: passo 13, immagine 1 di 2 PowerBook 3400 M3553 Display Replacement: passo 13, immagine 2 di 2
    • The two T8 13 mm torx screws hold the display screen in place. Be sure to remove the screws while supporting the screen or else it will fall.
    • Remove the two T8 13 mm long torx screws on either side of the display, located under the side panels.
    • Gently pull the display free of the computer.
Conclusione
To replace the display, follow these instructions in reverse order.
Cal Poly, Team 24-59, Amido Spring 2011 Membro di Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Membri
9 Guide realizzate
2 Commenti
Note that the side panels should be placed back BEFORE the audio panel.
Stanislav Ambartsumov - Replica
right, also I often had problems with placing the audio panel back into its place, it's three little plastic noses just didnt want to fit back into its notches of the back.
Jamba - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,945
