Salta al contenuto principale
Power Macintosh G3 Blue and White Modem Replacement
Cosa ti serve
  1. Power Macintosh G3 Blue and White Modem Replacement, Before opening up your Power Mac...: passo 1, immagine 1 di 1
    • Remove the Phillips #1 screw circled in the picture. Set it aside for re-assembly.
  2. Power Macintosh G3 Blue and White Modem Replacement: passo 2, immagine 1 di 1
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  3. Power Macintosh G3 Blue and White Modem Replacement: passo 3, immagine 1 di 1
    • Remove the single Phillips #1 screw circled in the picture.
    • I apologize for the lack of picture quality. The only camera and lighting I had were my iPhone X´s camera and a table lamp. Lol!
  4. Power Macintosh G3 Blue and White Modem Replacement: passo 4, immagine 1 di 1
    • Disconnect the modem’s flex cable from the connector on the logic board.
    • Lift the modem assembly out of it´s place on the logic board.
Conclusione
Altre 2 persone hanno completato questa guida.
[deleted]
Membro da: 08/28/18
26.475 Reputazione
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 648
