Salta al contenuto principale
Power Mac G5 CD-ROM Drive Replacement
  1. Power Mac G5 CD-ROM Drive Replacement, Side Panel: passo 1, immagine 1 di 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 CD-ROM Drive Replacement: passo 2, immagine 1 di 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 CD-ROM Drive Replacement: passo 3, immagine 1 di 2 Power Mac G5 CD-ROM Drive Replacement: passo 3, immagine 2 di 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 CD-ROM Drive Replacement: passo 4, immagine 1 di 3 Power Mac G5 CD-ROM Drive Replacement: passo 4, immagine 2 di 3 Power Mac G5 CD-ROM Drive Replacement: passo 4, immagine 3 di 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 CD-ROM Drive Replacement, CD-ROM Drive: passo 5, immagine 1 di 1
    • Locate the CD-ROM Drive on the top left corner of desktop.
  6. Power Mac G5 CD-ROM Drive Replacement: passo 6, immagine 1 di 3 Power Mac G5 CD-ROM Drive Replacement: passo 6, immagine 2 di 3 Power Mac G5 CD-ROM Drive Replacement: passo 6, immagine 3 di 3
    • Pull and rotate latches to the left.
  7. Power Mac G5 CD-ROM Drive Replacement: passo 7, immagine 1 di 1
    • Wiggle and pull out the CD Drive.
  8. Power Mac G5 CD-ROM Drive Replacement: passo 8, immagine 1 di 2 Power Mac G5 CD-ROM Drive Replacement: passo 8, immagine 2 di 2
    • Detach the first cable from the CD-ROM drive.
    • Detach the second cable from the CD-ROM drive.
    • On some models, the IDE cable is stuck to the top of the CD-ROM with foam tape. It is easier to unplug the IDE connector from the motherboard, and de-route the IDE cable as you remove the drive.
  9. Power Mac G5 CD-ROM Drive Replacement: passo 9, immagine 1 di 1
    • After the CD-ROM drive is removed, the area should look like this.
Conclusione
Altre 43 persone hanno completato questa guida.
Cal Poly, Team 5-8, Forte Winter 2010 Membro di Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Membri
20 Guide realizzate
Un commento
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
nirv - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 34,689
