Salta al contenuto principale
Power Mac G4 MDD Hard Drives Replacement
Cosa ti serve
  1. Power Mac G4 MDD Hard Drives Replacement, Case: passo 1, immagine 1 di 2 Power Mac G4 MDD Hard Drives Replacement, Case: passo 1, immagine 2 di 2
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD Hard Drives Replacement: passo 2, immagine 1 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 2, immagine 2 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 2, immagine 3 di 3
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD Hard Drives Replacement, Hard Drives: passo 3, immagine 1 di 1
    • The hard drive cages are located here.
  4. Power Mac G4 MDD Hard Drives Replacement: passo 4, immagine 1 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 4, immagine 2 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 4, immagine 3 di 3
    • Cage 1
    • Start by removing this screw.
    • Remove the ATA-66/ IDE ribbon cable from the motherboard.
  5. Power Mac G4 MDD Hard Drives Replacement: passo 5, immagine 1 di 2 Power Mac G4 MDD Hard Drives Replacement: passo 5, immagine 2 di 2
    • Now, remove the power connection from the drives.
  6. Power Mac G4 MDD Hard Drives Replacement: passo 6, immagine 1 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 6, immagine 2 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 6, immagine 3 di 3
    • Push this tab down, and pull the cage toward you.
    • Now, you can set cage 1 aside.
  7. Power Mac G4 MDD Hard Drives Replacement: passo 7, immagine 1 di 2 Power Mac G4 MDD Hard Drives Replacement: passo 7, immagine 2 di 2
    • Cage 2:
    • Remove this Phillips screw:
    • Disconnect this IDE ribbon cable from the logic board.
  8. Power Mac G4 MDD Hard Drives Replacement: passo 8, immagine 1 di 2 Power Mac G4 MDD Hard Drives Replacement: passo 8, immagine 2 di 2
    • It's likely that there is a cable clip holding the ribbon cable to the case.
    • To remove it, push the end, and it should pop up.
  9. Power Mac G4 MDD Hard Drives Replacement: passo 9, immagine 1 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 9, immagine 2 di 3 Power Mac G4 MDD Hard Drives Replacement: passo 9, immagine 3 di 3
    • With the ribbon cable clip free, pull this tab towards you, slide the cage up until it hits the platform under the power supply, and pull it away.
    • Now, set the cage on top of the CPU, and remove the power connectors.
  10. Power Mac G4 MDD Hard Drives Replacement: passo 10, immagine 1 di 2 Power Mac G4 MDD Hard Drives Replacement: passo 10, immagine 2 di 2
    • Once the cables are free, set the drive cage aside.
    • To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, then slide the drives out.
    • The two cages are cross compatible and can be put in either location.
    • The MDD does not have a 128GB drive limit like older Macs. My MDD has 3 drives (a 400GB Hitatchi Deskstar, 40GB Seagate Barracuda 7200.7, and a 30GB Quantum Fireball LCT).
    • Note the ID jumpers on the two drive set. One is set to Master, the other to slave. A single drive can be set to Cable Select.
Conclusione
Altre 33 persone hanno completato questa guida.
Chris Green
Membro da: 10/11/09
37.107 Reputazione
49 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.498 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 93
Tutti i Tempi: 47,173
