Salta al contenuto principale
Power Mac G4 MDD AirPort Card Replacement
Cosa ti serve
  1. Power Mac G4 MDD AirPort Card Replacement, Case: passo 1, immagine 1 di 2 Power Mac G4 MDD AirPort Card Replacement, Case: passo 1, immagine 2 di 2
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD AirPort Card Replacement: passo 2, immagine 1 di 3 Power Mac G4 MDD AirPort Card Replacement: passo 2, immagine 2 di 3 Power Mac G4 MDD AirPort Card Replacement: passo 2, immagine 3 di 3
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD AirPort Card Replacement, AirPort Card: passo 3, immagine 1 di 3 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: passo 3, immagine 2 di 3 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: passo 3, immagine 3 di 3
    • The AirPort card is located next to the graphics card.
    • If your computer has a FireWire 800 port between the FireWire 400 Ports and the Ethernet Ports then your computer uses an AirPort Extreme 802.11g Card (See Related Parts). If your computer has no firewire 800 port, then your computer uses an 802.11b AirPort PCMCIA Card (Also See Related Parts). Removal of both cards is pretty much the same.
    • First disconnect the antenna from the card, it may be helpful to use a spudger or flathead screwdriver.
    • Now, grasp the plastic tab on the back of the card and pull it out of the computer.
  4. Power Mac G4 MDD AirPort Card Replacement: passo 4, immagine 1 di 1
    • The Airport 802.11b PCMCIA Card.
Conclusione
Altre 13 persone hanno completato questa guida.
Chris Green
Membro da: 10/11/09
37.077 Reputazione
49 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.498 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 39
Tutti i Tempi: 28,687
