Salta al contenuto principale
Philips Steam Iron GC 1905 Power Cord Replacement
Cosa ti serve
  1. Philips Steam Iron GC 1905 Power Cord Replacement, Power cord replacement: passo 1, immagine 1 di 1
    • Switch off and unplug the iron. Drain the water from the water tank.
    • To prevent damage to the soleplate of the iron, make sure the worktop surface is non-abrasive.
    • Make sure the iron has cooled down before you start disassembly.
  2. Philips Steam Iron GC 1905 Power Cord Replacement: passo 2, immagine 1 di 2 Philips Steam Iron GC 1905 Power Cord Replacement: passo 2, immagine 2 di 2
    • Turn over to the triangular backplate of the steam iron.
    • Remove the 10.0 mm screw securing the backplate to the main body with a Phillips #1 screwdriver.
  3. Philips Steam Iron GC 1905 Power Cord Replacement: passo 3, immagine 1 di 3 Philips Steam Iron GC 1905 Power Cord Replacement: passo 3, immagine 2 di 3 Philips Steam Iron GC 1905 Power Cord Replacement: passo 3, immagine 3 di 3
    • Wedge your thumb and fingers at the joint between the backplate and the handle to loosen the snap joints.
    • Be mindful of the snap joints as they may break if excess pressure is applied.
    • We advise against use of screwdriver to pry open the backplate as it may damage snap joints.
    • Pull out the backplate gently to reveal the electric circuit—it will be still be connected to the wires so don't yank it off.
    • Take a photo of the electrical circuit to use as reference in step 5.
  4. Philips Steam Iron GC 1905 Power Cord Replacement: passo 4, immagine 1 di 3 Philips Steam Iron GC 1905 Power Cord Replacement: passo 4, immagine 2 di 3 Philips Steam Iron GC 1905 Power Cord Replacement: passo 4, immagine 3 di 3
    • Grip the green cable as close to the crimp connector as possible.
    • For easy removal, pinch the crimp connector between your thumb and forefinger. Apply force to the connector rather than the cable.
    • Slide out the crimp connector attached to the cable.
    • Applying force to the cable might separate the wire from the connector and leave the crimp connector in the slot.
    • Repeat the previous step to remove the red and black cables and take out the power cord.
  5. Philips Steam Iron GC 1905 Power Cord Replacement: passo 5, immagine 1 di 3 Philips Steam Iron GC 1905 Power Cord Replacement: passo 5, immagine 2 di 3 Philips Steam Iron GC 1905 Power Cord Replacement: passo 5, immagine 3 di 3
    • To connect the new cables, align and slide the crimp connector on the green cable into vacant slot.
    • Repeat the above step for the red and black cables.
    • Make sure the green, red and black cables are inserted in the correct slots.
  6. Philips Steam Iron GC 1905 Power Cord Replacement: passo 6, immagine 1 di 1
    • Before reassembly, ensure that the cord does not obstruct the screw slot.
Conclusione
Happy Fixing!
Altre 5 persone hanno completato questa guida.
2 Commenti
het l'ange deksel was al door mij losgemaakt
2 klips in het midden ...kon niet verder Los krijgen
wat moet ik verser doen zonder stukken te maken stroomdraad is stuk ????
QUISQUATER ETIENNE - Replica
But where do I find new wire online
Bharath Reddy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 206
Tutti i Tempi: 6,730
