Salta al contenuto principale
Peugeot Boxer Headlamp Bulb Replacement
Cosa ti serve
  1. Peugeot Boxer Headlamp Bulb Replacement, Bonnet Catch: passo 1, immagine 1 di 1
    • Open the passenger side door to find the bonnet release catch.
    • Pull the catch down and towards you to release the bonnet of the van.
  2. Peugeot Boxer Headlamp Bulb Replacement, Secondary Bonnet Catch: passo 2, immagine 1 di 1
    • Once the bonnet is loosened, find the yellow handle of the secondary bonnet catch by feeling underneath
    • Once you locate the catch, push the bonnet catch upwards, this will release the bonnet
  3. Peugeot Boxer Headlamp Bulb Replacement, Open Bonnet: passo 3, immagine 1 di 1
    • Use the strut, located to the right of the hood to prop open the bonnet.
    • Make sure the strut is secure to the hood! If the strut comes down, this may damage your car and strut!
  4. Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: passo 4, immagine 1 di 2 Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: passo 4, immagine 2 di 2
    • Remove the two Torx bolts holding the headlamp assembly at each corner.
  5. Peugeot Boxer Headlamp Bulb Replacement, Slide Headlamp Out: passo 5, immagine 1 di 1
    • Gently slide headlamp assembly out
    • Make sure to move the headlight diagonally towards you and towards the centre of the vehicle
  6. Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: passo 6, immagine 1 di 2 Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: passo 6, immagine 2 di 2
    • Pull the tab on rubber cap, revealing the back of the headlamp bulb.
  7. Peugeot Boxer Headlamp Bulb Replacement, Disconnect Bulb: passo 7, immagine 1 di 1
    • Remove the electrical connection from the old bulb (it should just pull off).
    • Make a note of which way up the plug was for when you connect everything back up again.
  8. Peugeot Boxer Headlamp Bulb Replacement, Remove Bulb: passo 8, immagine 1 di 1
    • With needle-nosed pliers, carefully 'wiggle' the old bulb out from its housing.
  9. Peugeot Boxer Headlamp Bulb Replacement, New Bulb: passo 9, immagine 1 di 1
    • Locate your new bulb. Taking care to make sure it is the right way up, push it firmly into place until you feel it clip in.
Conclusione
Altre 2 persone hanno completato questa guida.
Kit Marsden
Membro da: 05/04/21
404 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 125
Tutti i Tempi: 4,113
