This guide will show you how to replace the stove element, which is also referred to as the bake element or oven heating element. If your electric stove or oven’s heating element is cracked or blistered, or isn’t completely bright orange during usage, then it is most likely damaged. It is important to understand how to replace an oven’s heating element because keeping it damaged can lead to many issues, such as food not being cooked properly, or at all. As for the process itself, having prior experience with using screwdrivers and voltage meters will make things easier for you. Also, it is important for safety reasons to always ensure that the power to the stove is off when trying to repair it.
Consult the manual for your oven or stove to determine what type of replacement element you need.
Before replacing the heating element, try replacing the fuses.
