Salta al contenuto principale
NuVision 10.1 Atom Battery Replacement
Cosa ti serve
  1. NuVision 10.1 Atom Battery Replacement, Camera: passo 1, immagine 1 di 3 NuVision 10.1 Atom Battery Replacement, Camera: passo 1, immagine 2 di 3 NuVision 10.1 Atom Battery Replacement, Camera: passo 1, immagine 3 di 3
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. NuVision 10.1 Atom Battery Replacement: passo 2, immagine 1 di 1
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. NuVision 10.1 Atom Battery Replacement: passo 3, immagine 1 di 3 NuVision 10.1 Atom Battery Replacement: passo 3, immagine 2 di 3 NuVision 10.1 Atom Battery Replacement: passo 3, immagine 3 di 3
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. NuVision 10.1 Atom Battery Replacement, Speaker: passo 4, immagine 1 di 1
    • Carefully remove silver tape with your fingers.
  5. NuVision 10.1 Atom Battery Replacement: passo 5, immagine 1 di 2 NuVision 10.1 Atom Battery Replacement: passo 5, immagine 2 di 2
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. NuVision 10.1 Atom Battery Replacement, Motherboard: passo 6, immagine 1 di 1
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. NuVision 10.1 Atom Battery Replacement: passo 7, immagine 1 di 3 NuVision 10.1 Atom Battery Replacement: passo 7, immagine 2 di 3 NuVision 10.1 Atom Battery Replacement: passo 7, immagine 3 di 3
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. NuVision 10.1 Atom Battery Replacement: passo 8, immagine 1 di 2 NuVision 10.1 Atom Battery Replacement: passo 8, immagine 2 di 2
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. NuVision 10.1 Atom Battery Replacement: passo 9, immagine 1 di 3 NuVision 10.1 Atom Battery Replacement: passo 9, immagine 2 di 3 NuVision 10.1 Atom Battery Replacement: passo 9, immagine 3 di 3
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
  10. NuVision 10.1 Atom Battery Replacement, Battery: passo 10, immagine 1 di 3 NuVision 10.1 Atom Battery Replacement, Battery: passo 10, immagine 2 di 3 NuVision 10.1 Atom Battery Replacement, Battery: passo 10, immagine 3 di 3
    • Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
    • Using a metal spudger may bend or puncture the battery. Lithium batteries are prone to explode.
    • There is a lot of adhesive, take your time and be careful.
Conclusione
USF Tampa, Team S1-G5, Leahy Spring 2019 Membro di USF Tampa, Team S1-G5, Leahy Spring 2019
USFT-LEAHY-S19S1G5
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 876
