Salta al contenuto principale
Mission Hammr Bow String and Cables Replacement
  1. Mission Hammr Bow String and Cables Replacement, Strings and Cables: passo 1, immagine 1 di 1
    • Align the arms of the bow press with the limbs of the bow.
    • Ensure the bow press and bow arms are safe to use for this particular bow.
  2. Mission Hammr Bow String and Cables Replacement: passo 2, immagine 1 di 1
    • Slowly compress the bow press until the string has some slack similar to what's shown in the picture.
    • DO NOT press the bow anymore than you have to. This could result in damage to the bow and the bow press.
  3. Mission Hammr Bow String and Cables Replacement: passo 3, immagine 1 di 1
    • Before you remove the string or cables make sure you know where everything goes for replacement. Take a picture if needed.
  4. Mission Hammr Bow String and Cables Replacement: passo 4, immagine 1 di 1
    • Remove the string.
    • This is the easiest piece to put on and take off. Taking this off first will keep it out of the way so you can access the cables a bit more cleanly.
  5. Mission Hammr Bow String and Cables Replacement: passo 5, immagine 1 di 3 Mission Hammr Bow String and Cables Replacement: passo 5, immagine 2 di 3 Mission Hammr Bow String and Cables Replacement: passo 5, immagine 3 di 3
    • Now remove the cables one at a time.
    • After removing an old cable, immediately replace it with a new one. Doing this will make it easier to ensure you are replacing the cables in the correct spots.
    • The place the cable hooks onto the cam is labeled with a C. The string goes where it's imprinted with an S.
  6. Mission Hammr Bow String and Cables Replacement: passo 6, immagine 1 di 1
    • Once both sets of cables are replaced, make sure they are in the correct grooves before continuing.
  7. Mission Hammr Bow String and Cables Replacement: passo 7, immagine 1 di 2 Mission Hammr Bow String and Cables Replacement: passo 7, immagine 2 di 2
    • Replace the string.
  8. Mission Hammr Bow String and Cables Replacement: passo 8, immagine 1 di 1
    • Now with the string on and in the correct groove check through everything once more.
    • With the bow press, slowly tighten the strings and cables until it looks like it did before the replacement.
    • Use your before picture for a comparison to make sure it's correct.
  9. Mission Hammr Bow String and Cables Replacement: passo 9, immagine 1 di 1
    • Now with the pressure back on the bow everything should be ready to go.
    • Double check to make sure the cables align in the tuning holes and the strings and cables have successfully been replaced.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 577
