Salta al contenuto principale
Maytag MVWX655DW1 Washer Basket Hub Replacement
Cosa ti serve
  1. Maytag MVWX655DW1 Washer Basket Hub Replacement, Washer Basket Hub: passo 1, immagine 1 di 1
    • Use a 1/4-in Flathead screwdriver to remove the three 5mm screws behind the washing machine.
  2. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 2, immagine 1 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 2, immagine 2 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 2, immagine 3 di 3
    • Tape the lid down so it does not open when removing.
    • Pull the lid forward with your thumbs while pushing against the washer with your fingers.
    • Lift the lid up and place on the slots located where you removed the screws from the back.
  3. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 3, immagine 1 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 3, immagine 2 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 3, immagine 3 di 3
    • Remove the cap from the agitator with your flat head screwdriver. It should pop right off.
    • Using your 7/16 socket, unscrew the bolt attaching the agitator to the motor shaft.
  4. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 4, immagine 1 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 4, immagine 2 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 4, immagine 3 di 3
    • Lift up on the agitator and it should slide off the motor shaft exposing the washer hub underneath.
    • If it is stuck, put bolt back in halfway. Tap the bolt with a hammer while pulling up on the agitator to jog it loose.
  5. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 5, immagine 1 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 5, immagine 2 di 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 5, immagine 3 di 3
    • Use your Phillips #3 screwdriver to pull the retaining slip out.
    • Unscrew the six screws with the same Phillips #3 screwdriver to remove the hub.
  6. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 6, immagine 1 di 2 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 6, immagine 2 di 2
    • Take the new hub and slide it over the motor shaft.
    • Align the holes by only slightly screwing in each screw and turning the hub until all holes are aligned and screws are in.
    • Tighten all screws and then put new retaining clip into hub.
Conclusione
Kyle
Membro da: 02/18/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 66
Ultimi 30 Giorni: 218
Tutti i Tempi: 8,530
