Salta al contenuto principale
Manatee V2S Intelligent Clothes Dryer Filter Replacement
Cosa ti serve
  1. Manatee V2S Intelligent Clothes Dryer Filter Replacement, Filter: passo 1, immagine 1 di 1
    • Turn the machine upside down.
  2. Manatee V2S Intelligent Clothes Dryer Filter Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the 3.5 mm screw holding the bottom case to the device.
  3. Manatee V2S Intelligent Clothes Dryer Filter Replacement: passo 3, immagine 1 di 1
    • Cut out about 10 cm of scotch tape.
    • Turn it over and go around your hand as shown in the image, which lets the adhesive side on the outside. (Because it is easy to remove dust)
    • You can also use any other ways to remove the dust, but make sure not to break the filter.
  4. Manatee V2S Intelligent Clothes Dryer Filter Replacement: passo 4, immagine 1 di 1
    • Take out the filter.
    • Tap the dust and particles into the garbage, remove the dust with scotch tape, or replace the filter.
  5. Manatee V2S Intelligent Clothes Dryer Filter Replacement: passo 5, immagine 1 di 2 Manatee V2S Intelligent Clothes Dryer Filter Replacement: passo 5, immagine 2 di 2
    • Check for broken/loose wiring and other connections.
    • Dust may not be the only reason for the poor performance.
    • Close the lid and replace the screw.
Conclusione
[deleted]
Membro da: 09/17/21
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 502
