Salta al contenuto principale
MacBook Pro 15" Unibody Mid 2009 Feet Replacement
Cosa ti serve
  1. MacBook Pro 15" Unibody Mid 2009 Feet Replacement, Lower Case: passo 1, immagine 1 di 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 2, immagine 1 di 2 MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 2, immagine 2 di 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 Feet Replacement, Feet: passo 3, immagine 1 di 3 MacBook Pro 15" Unibody Mid 2009 Feet Replacement, Feet: passo 3, immagine 2 di 3 MacBook Pro 15" Unibody Mid 2009 Feet Replacement, Feet: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 4, immagine 1 di 1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 5, immagine 1 di 1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 6, immagine 1 di 1
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 7, immagine 1 di 3 MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 7, immagine 2 di 3 MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 7, immagine 3 di 3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 15" Unibody Mid 2009 Feet Replacement: passo 8, immagine 1 di 1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
Conclusione
Altre 6 persone hanno completato questa guida.
Adam O'Camb
Membro da: 04/11/15
197.590 Reputazione
416 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,365
