Salta al contenuto principale
MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement
Cosa ti serve
  1. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement: passo 2, immagine 1 di 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
Conclusione
Altre 18 persone hanno completato questa guida.
Un commento
Walter, please, change this guide's difficulty from moderate to easy :D
It's really that simple.
P.S. You've really saved me. I opened it by myself but then noticed that screws were different size. Oh, I always remember iFixit and opened it cuz I was sure that I'll find smth here. Many thanks!
Jizo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 64
Tutti i Tempi: 29,891
