Introduzione
Upgrade or replace the SuperDrive (requires a slim drive).
Cosa ti serve
Panoramica Video
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two Phillips screws in the battery compartment near the latch.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
Altre 59 persone hanno completato questa guida.
3 Commenti
This worked like a charm (and I bought myself a new toolset that absolutely rocked) Thanks iFixIt folks. I need to make a tiny adjustment somewhere as the eggshell clasp is a bit hard to open now, but that is a small deal compared to the non-functional CD I had.
After installing an SSD instead of the optical drive, installing Mac OS on it (the SSD) and then booting from the SSD, I can't get the computer to enter sleep mode. When I had the SSD connected (with the same OS installation) to an external USB port I had no trouble putting the beast to sleep (when booting from it)! Any suggestions? Obviously the SSD is now attached via (S)ATA instead of USB. Does it matter?
If I boot from the "original" SATA hard disk sleep mode works fine with the SSD installed (both via USB and in the optical bay)...
Is this superdrive reusable with an USB-adapter or enclosure ? Didn’t find a clear answer…
