Introduzione
Use this guide to replace the AirPort card.
Cosa ti serve
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Altre 17 persone hanno completato questa guida.
