Salta al contenuto principale
MacBook Air 13" Mid 2012: loose or rattling trackpad repair
Cosa ti serve
  1. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Battery: passo 3, immagine 1 di 2 MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Battery: passo 3, immagine 2 di 2
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
    • When reinstalling a new battery, it may be helpful to temporarily reconnect the battery before placing it in the frame. Make sure that the connector lays flat to the board.
  4. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 4, immagine 1 di 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  5. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 5, immagine 1 di 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • When installing the new battery, if there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Trackpad: passo 6, immagine 1 di 2 MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Trackpad: passo 6, immagine 2 di 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap (on the side opposite the cable), not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
  7. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 7, immagine 1 di 2 MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 7, immagine 2 di 2
    • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
  8. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 8, immagine 1 di 1
    • Remove the following twelve screws:
    • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
    • Six 1.6 mm Phillips screws securing the trackpad brackets to the trackpad.
    • A Phillips #000 should be sufficient, but a JIS #000 may also work as well.
  9. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 9, immagine 1 di 1
    • Remove the right and left trackpad brackets from the upper case.
  10. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 10, immagine 1 di 1
    • Remove the 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
    • During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the movable side of the trackpad has minimal play.
  11. MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 11, immagine 1 di 2 MacBook Air 13" Mid 2012: loose or rattling trackpad repair: passo 11, immagine 2 di 2
    • Use the flat edge of a spudger to carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
    • Remove the trackpad from the upper case.
  12. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Clean seat: passo 12, immagine 1 di 1
    • This is the seat of the buffer.
    • You will find the rest of the rotten buffer here, which made your trackpad rattle
    • Peel it off and clean with some alcohol or similar untill you see the raw aluminium surface
  13. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Cut and position double sided tape: passo 13, immagine 1 di 2 MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Cut and position double sided tape: passo 13, immagine 2 di 2
    • Cut two tiny (approx. 1,5 x 4 mm) pieces of double sided adhesive tape and place them on the seat
    • the red colour comes form the protective film of Tesa 4965, which works perfectly for this job. But principally any double sided tape, which is not too thick should do
    • On the second photo you see the empty seat on the left and the prepared one on the right
  14. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Cut foam buffer: passo 14, immagine 1 di 1
    • Now cut a piece of foam material of the same size. My foam material is black, and therefore a bit hard to see
    • In this case an EPDM foam was used, which can be compressed with little force but has a high longevity
    • The material must be below one milimeter thick! depending on your source material you will have to cut all tree dimensions
    • This took me many tries…
  15. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Position foam buffers: passo 15, immagine 1 di 2 MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Position foam buffers: passo 15, immagine 2 di 2
    • Peel off the protective film of the double sided tape and position the foam parts on both sides.
    • It should look more or less like on the photos
  16. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Reinstall Trackpad: passo 16, immagine 1 di 2 MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Reinstall Trackpad: passo 16, immagine 2 di 2
    • Reinstall trackpad by following step 8 in reverse order but only tighten the 6 screws at the trackpad (orange) firmly and leave the 6 screws of the case (red) slightly loose
    • Open the MacBook to nearly 90° so that it stands stable on its display case.
    • Check the feel of the click. Does it go back gently into rest position? Has it enough stroke?
    • If not, you might have chosen to rigid or to thick material (or both)
    • You may also try to readjust the central screw which is marked in step 10 and which you hopefully did not unscrew!
  17. MacBook Air 13" Mid 2012: loose or rattling trackpad repair, Adjust position of trackpad: passo 17, immagine 1 di 1
    • Finally center the trackpad in the case. This can easily be done by positioning a lamp behind the vertically standing lower case.
    • Move the trackpad in order to have an equal gap all around it. Then tighten the remaining 6 screws firmly to fix your adjustment.
    • Reassemble the rest going back from Step 8 and you're done!
Conclusione
Altre 4 persone hanno completato questa guida.
Marc Malkwitz
Membro da: 04/04/17
229 Reputazione
1 Guida realizzata
5 Commenti
Hello, good tutorial. Today on my Macbook Air disarm the trackpad, since it was loose and it sounded when using it. The only solution and that was good for me, was to tighten the central screw, to the point that it remained firm and allowed the clicks.
Another thing, the brackets I found on ebay, the pair at $ 5.
Ricardo Mujica - Replica
Very good guide. I did this yesterday on my Macbook Air Early 2014 and it solved the problem but as @ifixitkit mentioned in Step 8, “Removing the bracket is completely unnecessary”.
Pouyan - Replica
Thank you for the guide. I do advise against removing the 6 Philips screws attaching the trackpad to its hinges as described in Step 8. They simply don’t have to be removed, unless you’re replacing the trackpad.
My 2013 11” Air’s trackpad had started rattling after a battery swap and the noise drove me positively nuts. The trackpad does feel as good as new now. I used a ~1mm thick double sided foam tape instead of EPDM, hoping that it’s robust enough to last.
Einbert Alstein - Replica
Nice guide, my 5 year old machine had a loose trackpad that was making it difficult to register clicks and drags. All I had to do was step 10, not even remove the battery and the trackpad is as flush as new now 😊
Robert Dixon - Replica
Thank you so much! The trackpad of my MacBook Air 11'' early 2015 was ratteling because I changed the battery. I really couldn´t find out the problem. Than I found this guide and as mentioned I just had to adjust the screw in step 10 a little bit and now it is working perfectly again.
Matthias Jax - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 42
Tutti i Tempi: 11,498
