Salta al contenuto principale
MacBook Air 13" Late 2010 Display Assembly Replacement
Cosa ti serve
  1. MacBook Air 13" Late 2010 Display Assembly Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Late 2010 Display Assembly Replacement, Battery: passo 3, immagine 1 di 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  4. MacBook Air 13" Late 2010 Display Assembly Replacement, I/O Board Cable: passo 4, immagine 1 di 1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 5, immagine 1 di 2 MacBook Air 13" Late 2010 Display Assembly Replacement: passo 5, immagine 2 di 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • Carefully peel the I/O board cable from the top of the fan.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  6. MacBook Air 13" Late 2010 Display Assembly Replacement, Fan: passo 6, immagine 1 di 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  7. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 7, immagine 1 di 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  8. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 8, immagine 1 di 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  9. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 9, immagine 1 di 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  10. MacBook Air 13" Late 2010 Display Assembly Replacement, I/O Board: passo 10, immagine 1 di 1
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
  11. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 11, immagine 1 di 1
    • Pull the camera cable parallel to the face of the I/O board toward the corner of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
  12. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 12, immagine 1 di 2 MacBook Air 13" Late 2010 Display Assembly Replacement: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
    • De-route the left speaker cable from its retainer on the I/O board.
  13. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 13, immagine 1 di 1
    • Use the flat end of a spudger to pry the microphone cable connector up and out of its socket on the I/O board.
  14. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 14, immagine 1 di 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  15. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 15, immagine 1 di 1
    • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
  16. MacBook Air 13" Late 2010 Display Assembly Replacement, Battery: passo 16, immagine 1 di 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  17. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 17, immagine 1 di 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  18. MacBook Air 13" Late 2010 Display Assembly Replacement, Logic Board: passo 18, immagine 1 di 2 MacBook Air 13" Late 2010 Display Assembly Replacement, Logic Board: passo 18, immagine 2 di 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  19. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 19, immagine 1 di 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
  20. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 20, immagine 1 di 2 MacBook Air 13" Late 2010 Display Assembly Replacement: passo 20, immagine 2 di 2
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket by sliding it toward the corner of the Air.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  21. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 21, immagine 1 di 2 MacBook Air 13" Late 2010 Display Assembly Replacement: passo 21, immagine 2 di 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  22. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 22, immagine 1 di 1
    • Gently de-route the antenna cables from the slot cut into the logic board.
  23. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 23, immagine 1 di 1
    • Remove the single 2.85 mm T5 Torx screw securing the SSD to the logic board.
  24. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 24, immagine 1 di 1
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  25. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 25, immagine 1 di 1
    • Remove the six 6.3 mm T5 Torx screws securing the logic board to the upper case.
  26. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 26, immagine 1 di 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
  27. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 27, immagine 1 di 1
    • Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
  28. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 28, immagine 1 di 1
    • Hold the antenna cables out of the way as you lift the heat sink end of the logic board out of the upper case.
  29. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 29, immagine 1 di 1
    • Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
  30. MacBook Air 13" Late 2010 Display Assembly Replacement, Display Assembly: passo 30, immagine 1 di 1
    • Gently de-route the antenna cables out of the channel cut into the upper case.
  31. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 31, immagine 1 di 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
    • We intentionally have you leave the third screw in to aid in future steps.
  32. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 32, immagine 1 di 1
    • Open the display until it is perpendicular to the upper case and place it on a table as shown.
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
  33. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 33, immagine 1 di 1
    • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  34. MacBook Air 13" Late 2010 Display Assembly Replacement: passo 34, immagine 1 di 2 MacBook Air 13" Late 2010 Display Assembly Replacement: passo 34, immagine 2 di 2
    • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
    • Keep track of the shims under each of the two display brackets. When installing the display, be sure a shim is installed under each display bracket (against the upper case) as shown in the second picture.
Conclusione
Altre 71 persone hanno completato questa guida.
12 Commenti
Perfect! Thank You!
Ingo - Replica
Removing the logic board is completely unnecessary and you risk damaging more components. Follow steps 1-3, 11, 20-22, 26, 30-34. Obviously be careful not to damage the board when you are actually taking the display off.
Beau - Replica
Beau is correct . It isn't necessary at all to remove the logic board. Steps 1-3, 11, 20-22, 26, 30-34 are all that needs to be done.
Radiant Tech Repair -
For screen replacement only i did not have to remove board. So steps 16-19, 23-25, 29 are not needed.
Be careful on the step 12, my speaker connector fell off, I had to do some soldering to fix that. It is very gentle.
sdemyanov - Replica
Excellent guide, however, I would like to note that removing the logic board is completely unnecessary. In the process of doing so, I ended up breaking my right speaker socket from the logic board. The simpler method is to just unscrew the display hinge, antenna, and isight cable, then remove and replace display.
RoboMac - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 83
Tutti i Tempi: 82,055
