Salta al contenuto principale
Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement
Cosa ti serve
  1. Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement, Opening the Computer (2006-2008): passo 1, immagine 1 di 2 Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement, Opening the Computer (2006-2008): passo 1, immagine 2 di 2
    • Shut down the computer.
    • Warning: Always shut down the computer before opening it to avoid damaging its internal components or the components you are installing. Do not open the computer or attempt to install items inside it while it is on.
    • Wait 5 to 10 minutes to allow the computer’s internal components to cool.
    • Warning: After you shut down the system, the internal components can be very hot. You must let the computer cool down before continuing.
    • Unplug all external cables from the computer except the power cord.
    • Touch the metal PCI access covers on the back of the computer to discharge any static electricity from your body.
    • Unplug the power cord.
    • Put on an ESD wrist strap.
  2. Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement: passo 2, immagine 1 di 1
    • 1) Hold the side access panel and lift the latch on the back of the computer.
    • Warning: The edges of the access panel and the enclosure can be sharp. Be very careful when handling them.
    • 2) Remove the access panel and place it on a flat surface covered by a soft, clean cloth.
    • Replacement Note: Make sure the latch is in the up position before replacing the access panel. If the latch is down, the access panel will not seat correctly in the enclosure.
  3. Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement, Graphic Card for Mac Pro (2006-2008): passo 3, immagine 1 di 2 Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement, Graphic Card for Mac Pro (2006-2008): passo 3, immagine 2 di 2
    • This procedure explains how to remove a standard card and a card that includes a booster cable. Before you can remove either type of card, however, you must first loosen the two captive screws that secure the PCI bracket to the enclosure and remove the bracket.
  4. Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement: passo 4, immagine 1 di 1
    • Handle the card only by the edges.Do not touch its connectors or any of the components.Lift the card straight out from the connector to remove it, and insert it straight into the connector to install it.Do not rock the card from side to side and don’t force the card into the slot.Once the replacement card is installed, pull on it gently to check.
    • 1) Release the small locking clip at the front of the card’s logic board connector by pushing the clip up toward the media shelf.
    • 2) Holding the card by the top corners, pull up the card and remove it from its expansion slot.
  5. Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement, Card with Booster Cable: passo 5, immagine 1 di 2 Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement, Card with Booster Cable: passo 5, immagine 2 di 2
    • Some graphics cards require either one or two booster cables connecting the card to the auxillary power connectors on the logic board.
    • The graphics card NVIDIA GeForce 8800 GT requires one booster cable; the graphics card NVIDIA Quadro FX 5600 requires two booster cables.
    • Disconnect the booster cable(s) from the logic board.
    • Release the small locking clip at the front of the card’s logic board connector by pushing the clip up toward the media shelf.
    • Holding the card by the top corners, gently pull up the card and remove it from its expansion slot.
    • If you are replacing a booster cable with a new one, disconnect the cable from the card.
  6. Mac Pro Graphic Card for Mac Pro (2006-2008) Replacement: passo 6, immagine 1 di 1
    • Replacement Note for Card Using One Booster Cable: Be sure to connect the card’s booster cable to the correct auxillary power connector on the logic board. Connect the booster cable for a card in PCI slot 1 to the lower connector. Connect the booster cable for a card in PCI slot 2 to the upper connector.
    • Replacement Note for Card Using Two Booster Cables: Connect both cables to the two auxillary power connectors.
Conclusione
Altre 39 persone hanno completato questa guida.
Joshua Byrne
Membro da: 05/03/13
7.725 Reputazione
10 Guide realizzate
3 Commenti
1. In the step no 4, the picture itself was rotated 180' but the letters "1 " & "2" were not.
2. Is it better to show the small locking clip (of GPU) in logic board without GPU and with arrow direction in order to unlock (the GPU) ?
ChengCie Luo - Replica
I know from personal experience that installing those booster cables (if not present) is the biggest pain in the butt part of this job. Other than that it is super easy and anyone can do it.
Benjamin Dittman - Replica
What shall we do if we have a GPU that requires more than 300W? Or even two GPUs (in my case an Nvidia Quadro 4000 Mac Ed. + Nvidia GTX 1060)? Is there any other source of power available?
Adrien - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 165
Tutti i Tempi: 53,065
