Salta al contenuto principale
Lighting: Replacing Light Emitting Diode
Cosa ti serve
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: passo 1, immagine 1 di 1
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: passo 2, immagine 1 di 1
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: passo 3, immagine 1 di 1
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: passo 4, immagine 1 di 1
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: passo 5, immagine 1 di 1
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: passo 6, immagine 1 di 1
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to Come saldare e dissaldare componenti elettrici
  7. Lighting: Replacing Light Emitting Diode: passo 7, immagine 1 di 1
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: Come saldare e dissaldare componenti elettrici
  8. Lighting: Replacing Light Emitting Diode: passo 8, immagine 1 di 1
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 56
Tutti i Tempi: 4,747
