Salta al contenuto principale
K5 Desktop Humidifier Cotton Swab Filter Replacement
Cosa ti serve
  1. K5 Desktop Humidifier Cotton Swab Filter Replacement, Cotton Swab Filter: passo 1, immagine 1 di 1
    • Press and hold the humidifier switch. Check whether the connection to the power supply still works.
    • The purpose is to rule out a power failure that would render the humidifier inoperable.
  2. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 2, immagine 1 di 1
    • Use the spudger to slowly pry the middle part of the humidifier at the seam.
    • Be slow to open it, otherwise the humidifier outer body could be damaged.
  3. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 3, immagine 1 di 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 3, immagine 2 di 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 3, immagine 3 di 3
    • Remove the cotton swab and spring from inside the humidifier.
  4. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 4, immagine 1 di 1
    • Replace the old cotton swab filter with the new cotton swab.
  5. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 5, immagine 1 di 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 5, immagine 2 di 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 5, immagine 3 di 3
    • Put the new cotton swab into the humidifier.
    • Hand tighten the part where the cotton swab and humidifier meet.
    • The picture shows how it looks when fully installed.
  6. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 6, immagine 1 di 1
    • Reassemble the humidifier by snapping on the top half.
  7. K5 Desktop Humidifier Cotton Swab Filter Replacement: passo 7, immagine 1 di 1
    • Plug in the power adaptor to your USB port to use.
Conclusione
YikunFang
Membro da: 01/13/22
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 1,573
