Salta al contenuto principale
Install iJDMTOY HID Headlights
Cosa ti serve
  1. Install iJDMTOY HID Headlights, HID Headlight Bulb: passo 1, immagine 1 di 2 Install iJDMTOY HID Headlights, HID Headlight Bulb: passo 1, immagine 2 di 2
    • Open the hood and then locate the back of the headlights.
  2. Install iJDMTOY HID Headlights: passo 2, immagine 1 di 1
    • Remove the cap covers behind the headlights.
  3. Install iJDMTOY HID Headlights: passo 3, immagine 1 di 2 Install iJDMTOY HID Headlights: passo 3, immagine 2 di 2
    • Once you can see the OEM headlight bulb, twist and unlock to take it out.
  4. Install iJDMTOY HID Headlights: passo 4, immagine 1 di 2 Install iJDMTOY HID Headlights: passo 4, immagine 2 di 2
    • For a lot of D1S and D3S, there's a bulb retainer, which you will need to remove.
  5. Install iJDMTOY HID Headlights: passo 5, immagine 1 di 1
    • Examine your stock bulb. Make sure that the labeling on the OEM bulb is the same as the new HID bulb.
    • For example, this particular vehicle uses D1S stock bulb. You'll need to make sure that the HID replacement bulb is also labeled as D1S.
    • D1S and D3S are not interchangeable, so if you find that the labeling does not match, you will need to exchange for the correct size.
  6. Install iJDMTOY HID Headlights: passo 6, immagine 1 di 3 Install iJDMTOY HID Headlights: passo 6, immagine 2 di 3 Install iJDMTOY HID Headlights: passo 6, immagine 3 di 3
    • Take a look at the pins inside of the bulb. You can see that there is 1 pin by itself, a gap, and then 2 pins together. When you connect the new HID headlight bulb to the adapter, the pin direction needs to match! Look closely at the adapter and you will see numbers denoting slots 1,2, and 4.
    • Make sure that the pins on the HID headlight bulb and the pin slots on the adapter directly match prior to connection. If you connect the HID headlight bulb and the adapter the wrong way, the connection will still go in, but the incorrect insert WILL cause the bulb to have issues such as not lighting up, flickering, or damage to your vehicle.
    • So before connecting the HID headlight bulb to the adapter, make sure that the pins from the HID headlight bulb match the corresponding open slots on the adapter.
  7. Install iJDMTOY HID Headlights: passo 7, immagine 1 di 2 Install iJDMTOY HID Headlights: passo 7, immagine 2 di 2
    • Now you can install the HID headlight bulb back with the original retainer and then insert it back the same way you removed the OEM bulb.
  8. Install iJDMTOY HID Headlights: passo 8, immagine 1 di 2 Install iJDMTOY HID Headlights: passo 8, immagine 2 di 2
    • Put all the components back in place and enjoy your new HID headlights.
Conclusione
As you can see, it's very straight forward to install. Installing this iJDMTOY HID Replacement Bulb will give you light when yours burnt out.
Altre 5 persone hanno completato questa guida.
Eric Wu
Membro da: 01/21/15
3.357 Reputazione
23 Guide realizzate
10 Commenti
I am really impressed with your guide eric. As most people don't know how to change a light bulb. Well through your guide I am sure many people and companies like error free article writing services must have learned a lot from you. Well, keep sharing new guides with us.
alexa chris - Replica
I've heard that Samplius.com is a reliable source for online shopping. Has anyone else had any experience with the website? Is Samplius.com reliable?
Iron Dowman - Replica
If essay writing has always been one of the most challenging assignments for you, and choosing a trusted essay writing service has been even more complicated undertaking, ***https://www.writingpapersucks.com/ess... is the platform to consider.
NicolasS Samer - Replica
Regardless of your reason for needing political science essay https://essaysforme.com/write-my-politic...y writing help, we are here with reliable experts who work on assignments at even the toughest levels.nstead of rushing and delivering a substandard task to your institution, it's best to give it to one of our professionals. For one, they will provide you with a quality essay in return, while you put more focus into your other tasks. Secondly, you will get a perfect model of what your task should look like, which you can use for your future assignments!
hopkinsm - Replica
There are many popular Tower Defense games. Some of the best games include Bloons TD 6, Kingdom Rush Vengeance, Plants vs Zombies, and our web site has them all.
Duncan Jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 79
Tutti i Tempi: 3,664
