Salta al contenuto principale
Ibanez Bass Guitar String Replacement
Cosa ti serve
  1. Ibanez Bass Guitar String Replacement, String: passo 1, immagine 1 di 2 Ibanez Bass Guitar String Replacement, String: passo 1, immagine 2 di 2
    • In this picture you will find the headstock of the bass.
    • Turning the tuning peg counter clockwise to loosen the string.
    • Here you may use a drill as an easy and fast alternative.
  2. Ibanez Bass Guitar String Replacement: passo 2, immagine 1 di 2 Ibanez Bass Guitar String Replacement: passo 2, immagine 2 di 2
    • Pull the string from the bottom of the bass from the guitar's bridge.
  3. Ibanez Bass Guitar String Replacement: passo 3, immagine 1 di 2 Ibanez Bass Guitar String Replacement: passo 3, immagine 2 di 2
    • Pull the string through the guitar's bridge and upward though the headstock of the guitar.
  4. Ibanez Bass Guitar String Replacement: passo 4, immagine 1 di 2 Ibanez Bass Guitar String Replacement: passo 4, immagine 2 di 2
    • Wrap the new string around the corresponding tuning peg.
  5. Ibanez Bass Guitar String Replacement: passo 5, immagine 1 di 2 Ibanez Bass Guitar String Replacement: passo 5, immagine 2 di 2
    • Tighten the string by turning the tuning peg.
  6. Ibanez Bass Guitar String Replacement: passo 6, immagine 1 di 2 Ibanez Bass Guitar String Replacement: passo 6, immagine 2 di 2
    • Repeat steps 2 through 5 until you have changed all four strings.
Conclusione
After you remove the first string, you will reassemble and continue the process until you have changed all four strings.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 47
Tutti i Tempi: 141
