Salta al contenuto principale
Husqvarna Viking Designer 1 Needle Replacement
Cosa ti serve
  1. Husqvarna Viking Designer 1 Needle Replacement, Needle: passo 1, immagine 1 di 2 Husqvarna Viking Designer 1 Needle Replacement, Needle: passo 1, immagine 2 di 2
    • Remove the thread from the needle by pulling it out.
  2. Husqvarna Viking Designer 1 Needle Replacement: passo 2, immagine 1 di 3 Husqvarna Viking Designer 1 Needle Replacement: passo 2, immagine 2 di 3 Husqvarna Viking Designer 1 Needle Replacement: passo 2, immagine 3 di 3
    • Turn the knob counterclockwise to life up the needle.
    • Turning the knob clockwise can damage the machine.
  3. Husqvarna Viking Designer 1 Needle Replacement: passo 3, immagine 1 di 1
    • Place a sheet of paper under the foot. In the event that the needle falls out, this will prevent it from falling into the bobbin area.
  4. Husqvarna Viking Designer 1 Needle Replacement: passo 4, immagine 1 di 2 Husqvarna Viking Designer 1 Needle Replacement: passo 4, immagine 2 di 2
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to loosen the needle clamp screw (model: Viking #4125825-01) located next to the top of the needle with the other hand.
  5. Husqvarna Viking Designer 1 Needle Replacement: passo 5, immagine 1 di 1
    • Discard the broken or unwanted needle, and select a new one.
  6. Husqvarna Viking Designer 1 Needle Replacement: passo 6, immagine 1 di 2 Husqvarna Viking Designer 1 Needle Replacement: passo 6, immagine 2 di 2
    • Insert the new needle with the flat side facing away from you.
  7. Husqvarna Viking Designer 1 Needle Replacement: passo 7, immagine 1 di 1
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to tighten the needle clamp screw (model: Viking #4125825-01) with the other hand.
  8. Husqvarna Viking Designer 1 Needle Replacement: passo 8, immagine 1 di 1
    • Thread the needle. (See pages 8-10 from the link.)
    • You may now remove the sheet of paper and begin sewing!
Conclusione
Replacing the needle is a quick, easy task to complete, using the directions provided in this guide.
Un commento
Excellent illustration!!!
KO SAMUEL TAK SHUN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,312
