Salta al contenuto principale
How to replace a broken towel hook on drywall
Cosa ti serve
  1. How to replace a broken towel hook on drywall, Towel Hook: passo 1, immagine 1 di 2 How to replace a broken towel hook on drywall, Towel Hook: passo 1, immagine 2 di 2
    • Using your Phillips screwdriver, remove both screws that are keeping your current (broken) drywall hook in place.
    • Make sure you remove both screws evenly, to avoid bending and damaging the screws and the drywall around it.
  2. How to replace a broken towel hook on drywall: passo 2, immagine 1 di 1
    • After removing both screws, remove the plastic anchor screws from the drywall.
    • It will leave a big hole, but we will fix that!
  3. How to replace a broken towel hook on drywall: passo 3, immagine 1 di 3 How to replace a broken towel hook on drywall: passo 3, immagine 2 di 3 How to replace a broken towel hook on drywall: passo 3, immagine 3 di 3
    • After removing the anchor screws, take your spatula and press it flush with the wall. Remove debris from the drywall to make the wall flat.
  4. How to replace a broken towel hook on drywall: passo 4, immagine 1 di 2 How to replace a broken towel hook on drywall: passo 4, immagine 2 di 2
    • Take some patching and with your spatula, apply it on and around the holes in order to fill it up to the surface of the wall.
  5. How to replace a broken towel hook on drywall: passo 5, immagine 1 di 2 How to replace a broken towel hook on drywall: passo 5, immagine 2 di 2
    • Select a new location for your new towel hook and, with one of the screws, mark the spot where you'll drill the holes.
    • Use your screwdriver to tap the two new locations, to make it easier to screw the anchors onto the wall.
  6. How to replace a broken towel hook on drywall: passo 6, immagine 1 di 2 How to replace a broken towel hook on drywall: passo 6, immagine 2 di 2
    • Take your new anchor screws and start drilling on your marked holes.
    • Keep screwing them into the drywall until they're flush with the wall.
    • Don't drill too far, or else it will damage the drywall and the towel hook will be uneven!
  7. How to replace a broken towel hook on drywall: passo 7, immagine 1 di 3 How to replace a broken towel hook on drywall: passo 7, immagine 2 di 3 How to replace a broken towel hook on drywall: passo 7, immagine 3 di 3
    • Line up your new towel hook with the holes where the anchors are located.
    • Take your screws and start screwing them in manually so they stay in place.
  8. How to replace a broken towel hook on drywall: passo 8, immagine 1 di 1
    • With your screwdriver, continue screwing the screws in until they're flush with the towel hook.
  9. How to replace a broken towel hook on drywall: passo 9, immagine 1 di 1
    • Voila! Your new towel hook is installed!
    • But how about the hole we patched earlier?
  10. How to replace a broken towel hook on drywall: passo 10, immagine 1 di 2 How to replace a broken towel hook on drywall: passo 10, immagine 2 di 2
    • Press the sandpaper against the wall and scrub on and around the hole, to level it with the wall.
    • After doing that for a few seconds, your patch should be leveled and your problem, solved!
Conclusione
This guide shows both removing the old, broken towel hook and installing the new towel hook! Hope it helped!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,322
