Salta al contenuto principale
How to repair a hole in a crochet dishcloth
Cosa ti serve
  1. How to repair a hole in a crochet dishcloth, How to repair a hole in a crochet dishcloth: passo 1, immagine 1 di 1
    • Collect the tools and materials you'll need.
  2. How to repair a hole in a crochet dishcloth: passo 2, immagine 1 di 3 How to repair a hole in a crochet dishcloth: passo 2, immagine 2 di 3 How to repair a hole in a crochet dishcloth: passo 2, immagine 3 di 3
    • Identify any loose loops that may come undone if any yarn is pulled.
    • Put a safety pin through the loops, this will prevent the hole from getting any bigger.
  3. How to repair a hole in a crochet dishcloth: passo 3, immagine 1 di 3 How to repair a hole in a crochet dishcloth: passo 3, immagine 2 di 3 How to repair a hole in a crochet dishcloth: passo 3, immagine 3 di 3
    • Pick one of the loose strands and tie the yarn to this strand.
    • Make three knots to ensure the knot will not come undone.
  4. How to repair a hole in a crochet dishcloth: passo 4, immagine 1 di 3 How to repair a hole in a crochet dishcloth: passo 4, immagine 2 di 3 How to repair a hole in a crochet dishcloth: passo 4, immagine 3 di 3
    • Begin your first stitch by pushing the crochet hook through the stitch closest to the tied on yarn.
    • Next, wrap the yarn in front of the hook and pull it through the stitch making sure the hook catches the yarn.
  5. How to repair a hole in a crochet dishcloth: passo 5, immagine 1 di 3 How to repair a hole in a crochet dishcloth: passo 5, immagine 2 di 3 How to repair a hole in a crochet dishcloth: passo 5, immagine 3 di 3
    • Continuing on your first stitch, wrap the yarn in front of the hook and pull it in the direction of the arrow through the loop wrapped around the crochet hook.
    • Move on to the next stitch where the orange arrow is pointing. Continue making stitches around the hole until there is a small opening.
  6. How to repair a hole in a crochet dishcloth: passo 6, immagine 1 di 3 How to repair a hole in a crochet dishcloth: passo 6, immagine 2 di 3 How to repair a hole in a crochet dishcloth: passo 6, immagine 3 di 3
    • Once you have a small opening you will now close the hole. Using the same stitch used throughout the guide, make a stitch interlocking every other stitch.
    • The crochet hook should be moving in the direction the arrow is pointing.
  7. How to repair a hole in a crochet dishcloth: passo 7, immagine 1 di 3 How to repair a hole in a crochet dishcloth: passo 7, immagine 2 di 3 How to repair a hole in a crochet dishcloth: passo 7, immagine 3 di 3
    • Continuing until the hole is completely closed.
    • Cut the yarn leaving about a 4 inch tail.
    • Pull the loop in the direction the arrow is pointing.
  8. How to repair a hole in a crochet dishcloth: passo 8, immagine 1 di 3 How to repair a hole in a crochet dishcloth: passo 8, immagine 2 di 3 How to repair a hole in a crochet dishcloth: passo 8, immagine 3 di 3
    • Using the large threading needle, thread in all of the strands of yarn.
Conclusione
Rayme Ivers
Membro da: 05/04/20
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,975
