Salta al contenuto principale
How to fix an iPhone 4 home button
Cosa ti serve
  1. How to fix an iPhone 4 home button, Home Button: passo 1, immagine 1 di 3 How to fix an iPhone 4 home button, Home Button: passo 1, immagine 2 di 3 How to fix an iPhone 4 home button, Home Button: passo 1, immagine 3 di 3
    • Use the edge of an iPod opening tool or your fingernail to lift the home button ribbon cable retainer.
    • Be sure you are prying up on the cable retainer, not the socket itself.
  2. How to fix an iPhone 4 home button: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to pull the home button ribbon cable out of its socket.
    • Do not excessively strain the home button ribbon cable, as it is very thin and delicate. Also, be careful with the two small electronic parts on the ribbon cable. It is very easy to damage them with tweezers.
  3. How to fix an iPhone 4 home button: passo 3, immagine 1 di 1
    • De-route the home button ribbon cable through the inner case and remove the home button from the iPhone.
    • When installing a new part, there may be a protective plastic film on the home button. It can be removed with a spudger or your fingernail.
  4. How to fix an iPhone 4 home button, How to fix an iPhone 4 home button: passo 4, immagine 1 di 1
    • You need really thin blade to carefully peel off the plastic film from the back of the button. Do NOT touch the glue with your finger!
  5. How to fix an iPhone 4 home button: passo 5, immagine 1 di 3 How to fix an iPhone 4 home button: passo 5, immagine 2 di 3 How to fix an iPhone 4 home button: passo 5, immagine 3 di 3
    • After disassembly, you need some white spirit and cotton buds to clean up greenish oxide on both: button back contacts and steel cap's inside.
    • Last picture shows cleaned details.
  6. How to fix an iPhone 4 home button: passo 6, immagine 1 di 1
    • On reassembly, you have to position the steel cap in the center of copper contact ring, placing plastic sticker into its respective cavity on the back of the button.
    • Press the sticker firmly into its place. Don't worry if it doesnt stick all the way round. its position under the glass keeps the details in place. Again, try to prevent touching the glue while disassembling.
    • Congrats! Re-assemble your device and enjoy your revived home button!
Conclusione
Altre 37 persone hanno completato questa guida.
Tarmo Palm
Membro da: 09/01/13
2.584 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 48,031
