Salta al contenuto principale
How to fix Mobee Magic Mouse disconnection issues
Cosa ti serve
Istruzioni Video
Linea Traguardo
Altre 30 persone hanno completato questa guida.
4 Commenti
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Replica
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Replica
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Replica
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 238
Tutti i Tempi: 36,757
