Introduzione
Background Information
While Minecraft's multiplayer can be a fun shared experience, sometimes you just want to have that experience with yourself and a small group of friends. Now while there are options like Minecraft Realms, these options are on a monthly subscription and can get quite expensive.
But there is a much cheaper alternative, which is to make your own dedicated Minecraft Server. The best part is that you don't necessarily need to spend a whole lot of money on hardware unless you plan on hosting hundreds of players.
What you will need
While you can run a Minecraft Server on almost any computer, that can run Java, I will be using an 8GB Raspberry Pi 4 and a 32GB microSD card with Ubuntu flashed to it.
To start your server make sure the device you are using has the latest software update. This ensures the device has the latest security patches.
To run the Minecraft server you will need the latest Java Development Kit. For Linux you will just run the following command: sudo apt install default-jdk
Download the latest .jar file from the Mojang website here onto the device acting as your server.
In your command line, navigate to the directory that has your .jar file and run the following command...
java -Xmx3000M -Xms3000M -jar server.jar nogui
Congratulations! You now have your own private Minecraft server.
While this tutorial should give you a good foundation for making a server, some other good practices should be observed.
Firstly, it is recommended that you learn how to backup your server, as to not lose any progress that would have been made. A tutorial for that can be found here, but it is recommend you learn how to configure your device to a RAID 1 configuration. This way if your main storage fails you will have a copy on a spare storage drive.
Otherwise, you now have a private server that you and your friends can play on.
