Salta al contenuto principale
How to Take Care of Your Laptop So It Does not Break
Cosa ti serve
  1. How to Take Care of Your Laptop So It Does not Break, How to Take Care of Your Laptop So It Does not Break: passo 1, immagine 1 di 1
    • Keep liquids and food away from your laptop. If liquid gets into the inside of it, it could make your perfectly running device a fire hazard or you could suffer a data loss due to the damage
  2. How to Take Care of Your Laptop So It Does not Break: passo 2, immagine 1 di 1
    • Keep your laptop in a dust-free environment. You can get the outsides, and clean the body of the device, but you cannot open it up and dust it. Dust and particles might inside it and end up making it slower.
  3. How to Take Care of Your Laptop So It Does not Break: passo 3, immagine 1 di 1
    • Do not touch your laptop with dirty or wet hands. If you have been eating or drinking something, unclean hands can cause an electrical failure in the circuit and damage your device.
  4. How to Take Care of Your Laptop So It Does not Break: passo 4, immagine 1 di 1
    • Do not lift your device holding the screen. Always use the base to hold it up. This will definitely increase the life of your product.
  5. How to Take Care of Your Laptop So It Does not Break: passo 5, immagine 1 di 1
    • Be careful plugging in peripherals. Items you plug into the computer like USB drives or headphones or various adapters have ports into which they fit. Pay attention to the size and shape of connectors before inserting it into the respective port.
  6. How to Take Care of Your Laptop So It Does not Break: passo 6, immagine 1 di 1
    • Do not place anything on top of your laptop. Even light things can push the screen into the keyboard and damage the screen.
  7. How to Take Care of Your Laptop So It Does not Break: passo 7, immagine 1 di 1
    • Shut down your laptop regularly. Sometimes laptops begin to run sluggishly after being constantly on for a few days. Turning off your device to allow your laptop’s hardware to reset and have a rest.
  8. How to Take Care of Your Laptop So It Does not Break: passo 8, immagine 1 di 1
    • Get a laptop case. A hard-shell case may prevent damage from minor falls or random bumps.
  9. How to Take Care of Your Laptop So It Does not Break: passo 9, immagine 1 di 1
    • Take care of the battery. Battery life depends on how often you charge it. Consider keeping your laptop plugged all the time. Try not to use the better when possible.
Conclusione
While these might seem like easy things to do, more often than not, we forget to do these. This is a lesson to learn. Besides hardware security, take care of software and know how to get rid of the malware. Make sure you are safe, follow these instructions to give your laptop a longer and healthier life.
Altre 7 persone hanno completato questa guida.
David Balaban
Membro da: 12/08/20
667 Reputazione
2 Guide realizzate
2 Commenti
Thanks for the tips. in the area of battery, I don't fully understand the point there. is it advised to unplug the device when full or keep it plug always? from my laptop manual, I read that I should unplug when not charging, how do I correlate this? Thanks
Tim (Lovety4) - Replica
How do I fixmy keyboard of connex 14.1 dual core? Problem keystroke( U give me a number 4, keystroke nr 0 give me a /
qwerty456*asdfgh123-'zxcvbn0,,.+ z If I can just switch of the Fn key but I don't know how?please please whatsapp me on 0639632749 my name is Brenda! I am DESPERATE PLEASE!! I have a bluetooth keyboard as well but it connect to the computer and then they ask me to put in the numbers that appear on the screen. But I can not see any numbers on the screen. I think I may have dig into my display and change something there I don't know please help me???😢😢😢😢😱
Brenda Snyders - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 104
Tutti i Tempi: 2,177
