Salta al contenuto principale
How to String a Tennis Racket
Cosa ti serve
  1. How to String a Tennis Racket, Cut the old strings from the tennis racket: passo 1, immagine 1 di 2 How to String a Tennis Racket, Cut the old strings from the tennis racket: passo 1, immagine 2 di 2
    • Cut the old strings from the tennis racket using a pair of utility scissors and remove them.
    • Be careful not to cut yourself with the ends of the strings.
  2. How to String a Tennis Racket, Place the frame into a stringing machine: passo 2, immagine 1 di 1
    • Place the frame into a stringing machine by screwing in the four main screws and pulling the racket tight.
  3. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: passo 3, immagine 1 di 3 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: passo 3, immagine 2 di 3 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: passo 3, immagine 3 di 3
    • Insert the main vertical string into the head of the racket, and thread it down to the neck of the racket and back to the head.
    • Pull and tighten the first main string into a tension rod.
    • The strings should always go under the racquet.
  4. How to String a Tennis Racket, Secure and tighten the end of the string: passo 4, immagine 1 di 2 How to String a Tennis Racket, Secure and tighten the end of the string: passo 4, immagine 2 di 2
    • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the horizontal position.
    • Fix the second string utilizing the second clamp and release the first string.
    • Continue threading the main strings and clamping the strings until all holes have been strung.
    • The stringing pattern: Insert and tighten the string, secure the next string with the clamp, and release the previous string.
  5. How to String a Tennis Racket, Knot the main string: passo 5, immagine 1 di 2 How to String a Tennis Racket, Knot the main string: passo 5, immagine 2 di 2
    • Knot the main string after you have secured all the main strings.
    • Release the tension rod and cut off the remaining string.
  6. How to String a Tennis Racket, Horizontal cross strings: passo 6, immagine 1 di 1
    • Insert the horizontal cross strings from the left to the right and back to the left.
    • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the vertical position.
    • Continue threading the cross strings and clamping the strings until all holes have been strung by applying the stringing pattern.
    • Weave the cross strings by going over and under repeatedly through the main strings.
  7. How to String a Tennis Racket, Knot all the cross strings: passo 7, immagine 1 di 1
    • Knot all of the cross strings after you have secured them.
Conclusione
Tzu-Wei
Membro da: 09/19/20
153 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 83
Tutti i Tempi: 4,385
