Salta al contenuto principale
How to Sew a Hole in a Sock
Cosa ti serve
  1. How to Sew a Hole in a Sock, How to Sew a Hole in a Sock: passo 1, immagine 1 di 1
    • Cut about 15 inches of thread in a similar color to your sock.
  2. How to Sew a Hole in a Sock: passo 2, immagine 1 di 3 How to Sew a Hole in a Sock: passo 2, immagine 2 di 3 How to Sew a Hole in a Sock: passo 2, immagine 3 di 3
    • Pass the thread through the needle’s hole and knot it at the end.
  3. How to Sew a Hole in a Sock: passo 3, immagine 1 di 2 How to Sew a Hole in a Sock: passo 3, immagine 2 di 2
    • Turn the sock inside-out.
    • Flatten the sock.
  4. How to Sew a Hole in a Sock: passo 4, immagine 1 di 2 How to Sew a Hole in a Sock: passo 4, immagine 2 di 2
    • Starting at one corner of the hole, insert the needle through the edge and pull it out the other edge.
  5. How to Sew a Hole in a Sock: passo 5, immagine 1 di 2 How to Sew a Hole in a Sock: passo 5, immagine 2 di 2
    • Repeat Step 4, but now in the opposite direction not too far from the previous stitch.
  6. How to Sew a Hole in a Sock: passo 6, immagine 1 di 2 How to Sew a Hole in a Sock: passo 6, immagine 2 di 2
    • Continue repeating Steps 4 and 5 until you get to the end of the hole.
  7. How to Sew a Hole in a Sock: passo 7, immagine 1 di 1
    • Insert half of the needle and wrap the thread around the needle three times.
  8. How to Sew a Hole in a Sock: passo 8, immagine 1 di 2 How to Sew a Hole in a Sock: passo 8, immagine 2 di 2
    • While holding the thread, send the needle all the way through.
  9. How to Sew a Hole in a Sock: passo 9, immagine 1 di 2 How to Sew a Hole in a Sock: passo 9, immagine 2 di 2
    • Repeat Steps 8 and 9 one last time.
  10. How to Sew a Hole in a Sock: passo 10, immagine 1 di 2 How to Sew a Hole in a Sock: passo 10, immagine 2 di 2
    • Cut the excess thread with the scissors.
  11. How to Sew a Hole in a Sock: passo 11, immagine 1 di 1
    • Turn the sock so the right side is facing outwards.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 53
Tutti i Tempi: 2,689
