Salta al contenuto principale
How to Secure a Hook and Eye Fastener Properly
Cosa ti serve
  1. How to Secure a Hook and Eye Fastener Properly, How to Secure a Hook and Eye Fastener Properly: passo 1, immagine 1 di 1
    • Cut about 28 inches of thread and fold it in half which would be one loop and the two ends together.
    • Then thread the two ends through the eye of the needle.
  2. How to Secure a Hook and Eye Fastener Properly: passo 2, immagine 1 di 2 How to Secure a Hook and Eye Fastener Properly: passo 2, immagine 2 di 2
    • Slide the needle down the thread until you reach about two inches from the loop.
    • Position the needle between the loop and pull through.
    • This will create a knot at the base of the needle which will make the thread less tangled.
    • Next, pull on both ends of the thread to make them equal length before tying a knot.
  3. How to Secure a Hook and Eye Fastener Properly: passo 3, immagine 1 di 1
    • First, position the hook above the zipper and on the inside fabric, about 3mm from the edge.
  4. How to Secure a Hook and Eye Fastener Properly: passo 4, immagine 1 di 2 How to Secure a Hook and Eye Fastener Properly: passo 4, immagine 2 di 2
    • Remove the hook and start by sewing a stitch where your hook was.
    • Then trim the extra thread close to the knot.
  5. How to Secure a Hook and Eye Fastener Properly: passo 5, immagine 1 di 2 How to Secure a Hook and Eye Fastener Properly: passo 5, immagine 2 di 2
    • Sew on top of the knot three times to make sure it is secure.
    • Position the hook on top of the stitch.
    • Anchor the front part of the hook down by sewing over the bottom edge of the hook three times.
  6. How to Secure a Hook and Eye Fastener Properly: passo 6, immagine 1 di 1
    • Then poke the needle underneath the fabric and bring it up in one of the holes.
  7. How to Secure a Hook and Eye Fastener Properly: passo 7, immagine 1 di 2 How to Secure a Hook and Eye Fastener Properly: passo 7, immagine 2 di 2
    • Now hold the other eye of the hook in place.
    • The needle is going to go in from the outside of the wired edge to inside the circle and pull that through till you get a small loop.
    • After that push, the needle through that loop and pull which create a small knot.
    • Now repeat this stitch two more times.
  8. How to Secure a Hook and Eye Fastener Properly: passo 8, immagine 1 di 1
    • Then take the needle into the other hole, coming up in the center.
  9. How to Secure a Hook and Eye Fastener Properly: passo 9, immagine 1 di 1
    • Then repeat step 7 for this hole.
  10. How to Secure a Hook and Eye Fastener Properly: passo 10, immagine 1 di 1
    • After this, tie a knot.
    • Then cut the thread and tie a knot at the end of the thread.
  11. How to Secure a Hook and Eye Fastener Properly: passo 11, immagine 1 di 1
    • To position the eyes, place the hook and eyes together and line up the fabric so the edges match.
  12. How to Secure a Hook and Eye Fastener Properly: passo 12, immagine 1 di 2 How to Secure a Hook and Eye Fastener Properly: passo 12, immagine 2 di 2
    • Hold it in place with your fingers. Start by stitching across the wire and trim the tail near the knot.
    • Sew on top of the knot and the wire three times to make sure it is secure.
    • Making sure you come out from the middle of the eyes.
  13. How to Secure a Hook and Eye Fastener Properly: passo 13, immagine 1 di 1
    • After this, repeat step 7.
  14. How to Secure a Hook and Eye Fastener Properly: passo 14, immagine 1 di 2 How to Secure a Hook and Eye Fastener Properly: passo 14, immagine 2 di 2
    • Then repeat step 8 and 9.
    • It should look like this at the end.
Linea Traguardo
Cecilia
Membro da: 05/10/21
229 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 77
Tutti i Tempi: 1,017
