Salta al contenuto principale
How to Restore your Old Masterpieces on Wooden Canvases
Cosa ti serve
  1. How to Restore your Old Masterpieces on Wooden Canvases, How to Restore your Old Masterpieces on Wooden Canvases: passo 1, immagine 1 di 3 How to Restore your Old Masterpieces on Wooden Canvases, How to Restore your Old Masterpieces on Wooden Canvases: passo 1, immagine 2 di 3 How to Restore your Old Masterpieces on Wooden Canvases, How to Restore your Old Masterpieces on Wooden Canvases: passo 1, immagine 3 di 3
    • Assemble all necessary items.
    • Warning: Oil paints and oil paint restorers contain chemicals that can lead to injury and or death if improperly used. Please refer to the manufacturer safety guidelines for each product. Keep paint and paint restorers off of the skin. Paint in a well-ventilated area.
  2. How to Restore your Old Masterpieces on Wooden Canvases: passo 2, immagine 1 di 1
    • Use the hammer's peen to remove each nail from the painting on the frame.
    • Lightly remove the canvas from the frame.
    • Not all paintings are nailed to their frame. If your painting is attached to the frame in an alternative way, contact the framing company to discuss ways to the safely remove the frame.
  3. How to Restore your Old Masterpieces on Wooden Canvases: passo 3, immagine 1 di 1
    • Coat a cotton-tipped swab with oil painting restorer.
    • Rub the cotton-tipped swab on a small unnoticeable part of the painting to test a spot.
    • Wait a few minutes to see if the oil painting restorer caused damage to the painting.
    • You're looking for any obvious signs of damage such as paint chipping, discoloration, and bad order.
  4. How to Restore your Old Masterpieces on Wooden Canvases: passo 4, immagine 1 di 1
    • Coat a lint-free cloth with oil painting restorer.
    • Lightly rub the painting with your cloth until the entire painting is clean.
  5. How to Restore your Old Masterpieces on Wooden Canvases: passo 5, immagine 1 di 3 How to Restore your Old Masterpieces on Wooden Canvases: passo 5, immagine 2 di 3 How to Restore your Old Masterpieces on Wooden Canvases: passo 5, immagine 3 di 3
    • Mix oil paints together until you get the desired color.
    • Apply mixed paint to a small spot on the painting.
    • Wait for the mixed paint to dry on the painting.
    • After the paint dries, if the color does not match the original painting, then remix the stain and repeat this step until you get the desired color.
  6. How to Restore your Old Masterpieces on Wooden Canvases: passo 6, immagine 1 di 2 How to Restore your Old Masterpieces on Wooden Canvases: passo 6, immagine 2 di 2
    • Use a hammer to reattach the nails on the painting to your frame.
    • Physically move around the frame if needed.
    • If you have an alternate frame type, then follow the manufacturer guide to reattach the painting to the frame.
  7. How to Restore your Old Masterpieces on Wooden Canvases: passo 7, immagine 1 di 1
    • Varnish if needed.
Linea Traguardo
Tyler A Martinez
Membro da: 02/28/22
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 42
Tutti i Tempi: 500
