Salta al contenuto principale
How to Restore a Used Canvas
Cosa ti serve
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: passo 1, immagine 1 di 2 How to Restore a Used Canvas, How to Restore a Used Canvas: passo 1, immagine 2 di 2
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: passo 2, immagine 1 di 2 How to Restore a Used Canvas: passo 2, immagine 2 di 2
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: passo 3, immagine 1 di 1
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: passo 4, immagine 1 di 3 How to Restore a Used Canvas: passo 4, immagine 2 di 3 How to Restore a Used Canvas: passo 4, immagine 3 di 3
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: passo 5, immagine 1 di 1
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: passo 6, immagine 1 di 1
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: passo 7, immagine 1 di 3 How to Restore a Used Canvas: passo 7, immagine 2 di 3 How to Restore a Used Canvas: passo 7, immagine 3 di 3
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: passo 8, immagine 1 di 3 How to Restore a Used Canvas: passo 8, immagine 2 di 3 How to Restore a Used Canvas: passo 8, immagine 3 di 3
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
Linea Traguardo
Sandra Henriquez
Membro da: 04/21/21
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 28
Tutti i Tempi: 641
