Salta al contenuto principale
How to Restore a Damaged Cork Board
Cosa ti serve
  1. How to Restore a Damaged Cork Board, How to Restore a Damaged Cork Board: passo 1, immagine 1 di 1
    • Cover your work surface with a tarp.
  2. How to Restore a Damaged Cork Board: passo 2, immagine 1 di 1
    • Use a rag, soap, and water to scrub the damaged area to remove residual pieces of cork and glue.
    • Allow the area to dry.
  3. How to Restore a Damaged Cork Board: passo 3, immagine 1 di 1
    • Apply wood filler liberally on top of the holes.
  4. How to Restore a Damaged Cork Board: passo 4, immagine 1 di 2 How to Restore a Damaged Cork Board: passo 4, immagine 2 di 2
    • Smooth out the wood filler using a putty knife.
    • Hold the putty knife at an angle and use long strokes to flatten the filler as much as possible.
    • Wait 1 hour for the filler to dry.
  5. How to Restore a Damaged Cork Board: passo 5, immagine 1 di 1
    • Use 80-grit sandpaper to sand down the excess filler in a circular motion.
  6. How to Restore a Damaged Cork Board: passo 6, immagine 1 di 1
    • Cover the damaged area with a thin, even layer of wood sealant.
Conclusione
This guide will help you keep your old cork boards instead of trying to replace them. I hope you found our guide useful.
Annie Wilson
Membro da: 09/27/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 94
Tutti i Tempi: 472
