Salta al contenuto principale
How to Restore Wool’s Water Resistance
Cosa ti serve
  1. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: passo 1, immagine 1 di 3 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: passo 1, immagine 2 di 3 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: passo 1, immagine 3 di 3
    • Fill a bowl with water at room temperature (20 °C or 68 °F).
    • Use 2 L of water per 200 g of wool.
  2. How to Restore Wool’s Water Resistance: passo 2, immagine 1 di 1
    • Add 1/2 teaspoon of wool wash per 2 L of water.
  3. How to Restore Wool’s Water Resistance: passo 3, immagine 1 di 2 How to Restore Wool’s Water Resistance: passo 3, immagine 2 di 2
    • Insert the articles into the bowl and let soak for 30 minutes.
    • Carefully squeeze the items to allow absorption of soap and water through the wool fibres.
  4. How to Restore Wool’s Water Resistance: passo 4, immagine 1 di 1
    • Lift the items out of the water and gently squeeze to remove excess water and soap.
  5. How to Restore Wool’s Water Resistance: passo 5, immagine 1 di 1
    • Refill the bowl with room temperature water.
    • Use the same volume of water as in Step 1.
  6. How to Restore Wool’s Water Resistance: passo 6, immagine 1 di 2 How to Restore Wool’s Water Resistance: passo 6, immagine 2 di 2
    • Mix 4 tablespoons of emulsified lanolin into 2 liters of water.
  7. How to Restore Wool’s Water Resistance: passo 7, immagine 1 di 2 How to Restore Wool’s Water Resistance: passo 7, immagine 2 di 2
    • Add the articles and squeeze to saturate.
    • Weight the articles with a heavy glass or a dish.
    • Leave to soak for 30 minutes.
  8. How to Restore Wool’s Water Resistance: passo 8, immagine 1 di 2 How to Restore Wool’s Water Resistance: passo 8, immagine 2 di 2
    • Pull the articles out of the lanolin bath and gently squeeze out excess water.
  9. How to Restore Wool’s Water Resistance: passo 9, immagine 1 di 1
    • Lay flat to dry with a clean towel beneath the items.
    • Do not line dry. It can cause wool to stretch and lose shape.
    • Avoid direct sunlight or direct heat when drying.
Linea Traguardo
Yuliya S
Membro da: 01/17/22
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 500
